Selection groups not working?
altidude
Post by altidude » Mon Jun 13, 2011 10:37 pm
Selection groups do not seem to be working in version 4.0.1191.0 under Windows XP Pro SP3 32 bit.
altidude
Re: Selection groups not working?
Post by altidude » Wed Jun 15, 2011 4:24 pm
Any chance one of the developers could address this? I would really appreciate it.
Post by mb » Wed Jun 15, 2011 7:06 pm
The bug has been fixed and a fix will be in the next build.
Post by mb » Thu Jun 16, 2011 2:18 pm
The new version is now available: https://www.smartftp.com/download/
altidude
Post by altidude » Fri Jun 24, 2011 5:03 pm
Selection groups still not working in 1197 version. I assume it worked for you in testing?
Service Pack 3 (Build 2600)
CPU Speed : 2210 MHz
Total Memory : 1983 MB
Free Memory : 1341 MB
Version : 4.0.1197.0
Time Stamp : 2011-06-24 09:22:37
Maintenance : 2011-09-21
Days in use : 1576
Post by mb » Fri Jun 24, 2011 7:57 pm
Yes it is working here. What are you doing exactly?
altidude
Post by altidude » Fri Jun 24, 2011 8:22 pm
I'm entering my file wildcards in the Tools/Settings/Selection Groups box for the 10th position, miscellaneous files. I try to select those files using Ctrl-9 and nothing is selected.
I just found that selection works from the "Edit/Selection Groups" menu item, it's only Ctrl-9 that is not working. Probably any Ctrl-x actually. I've tried others but not all.
altidude
Post by altidude » Fri Jun 24, 2011 8:26 pm
I should add that this is on version 4.0.1195.0. I had to go back since 1197 wasn't downloading the queue.
Post by mb » Fri Jun 24, 2011 8:37 pm
Please try it again now with 1198.
altidude
Post by altidude » Fri Jun 24, 2011 9:21 pm
Ctrl-9 is still not working...
Version : 4.0.1198.0
Time Stamp : 2011-06-24 21:58:09
