Terminal SSH - Translate
DRon450
Post by DRon450 » Thu May 05, 2011 8:11 pm
I can't change remote charset when using Terminal over SSH. I need 1251 charset, I select it from list and press OK button, but charset is still UTF-8. When I open again Terminal Translate section, selected charset is UTF-8, so I think it's not save.
Re: Terminal SSH - Translate
Post by mb » Thu May 05, 2011 8:36 pm
Its a bug. I have fixed it. The bug fix will be available in the next build.
Post by mb » Thu May 19, 2011 12:15 am
The new version is available now: https://www.smartftp.com/download/
DRon450
Post by DRon450 » Thu May 26, 2011 1:27 pm
Thanks, but the problem still remained. In the new version I could save the character set used for the SSH connection. However, the program regardless of the chosen encoding uses UTF-8.
Post by mb » Thu May 26, 2011 4:41 pm
Thank you. It's another bug that has been corrected now. The bug fix comes with the next build.
Post by mb » Wed Jun 01, 2011 8:48 pm
DRon450
Post by DRon450 » Thu Jun 02, 2011 12:58 pm
Excellent!! Thanks!
