Multiple file monitoring
MerlinPerezGore
Post by MerlinPerezGore » Mon Apr 18, 2011 1:55 pm
I used to be able to select multiple files and set the schedule to monitor, which would monitor all these files individually, so that when I changed ONE file in the folder only THAT file would sync with the server. Now it seems you can only do this per folder, which cyncs the WHOLE folder every time, or go through the monitor process for every single file. When you're dealing with 100s of files, youd on't want to have to set the trigger for every individual file.
Why have you changed the way this works? If you retained this functionality, could you please tell me what i'm doing wrong?
Merlin
PS. Here are my system details:
Microsoft Windows 7
 (Build 7600)
CPU Speed           : 2405 MHz
Total Memory        : 4095 MB
Free Memory         : 1860 MB
Version             : 4.0.1176.0
Time Stamp          : 2011-03-27 23:25:07
Platform            : x64
Maintenance         : 2011-04-08
Days in use         : 10
en-US
Version             : 8.0.7600.16385
Winsock             : 2.2
Last edited by MerlinPerezGore on Mon Apr 18, 2011 1:56 pm, edited 1 time in total.
Re: Multiple file monitoring
Post by mb » Mon Apr 18, 2011 7:12 pm
The maintenance of your license has expired. Please renew it for premium support. Thank you.
MerlinPerezGore
Post by MerlinPerezGore » Mon Apr 18, 2011 7:18 pm
Okay I've renewed maintenance (Order # 41703061). Please can you help out now?
Microsoft Windows 7
 (Build 7600)
Free Memory         : 2380 MB
Platform            : x64
Maintenance         : 2012-04-18
Days in use         : 10
en-US
Winsock             : 2.2
Last edited by MerlinPerezGore on Mon Apr 18, 2011 7:24 pm, edited 1 time in total.
Post by mb » Mon Apr 18, 2011 8:36 pm
Thank you. How many files do you want to monitor at the same time? Are these files in different folders?
MerlinPerezGore
Post by MerlinPerezGore » Mon Apr 18, 2011 8:40 pm
The number of files is in the hundreds, and yes they are in different folders. I used to be able to drag and drop into the transfer queue which was paused, then right-click on all the files and set to monitor when edited, it seems I am no longer able to do that?
Post by mb » Mon Apr 18, 2011 9:51 pm
Since we have refactored the Scheduler this is no longer possible. But our application is open for 3rd party developers to write addons or standalone applications which can offer this functionality.
MerlinPerezGore
Post by MerlinPerezGore » Mon Apr 18, 2011 9:54 pm
Is there a way I can make the program watch a folder but only sync the files that have changed rather than the whole folder every time?
Post by mb » Mon Apr 18, 2011 9:56 pm
Yes this actually the default behavior for the folder monitor.
MerlinPerezGore
Post by MerlinPerezGore » Mon Apr 18, 2011 10:04 pm
So what am I doing wrong? I set the folder to monitor changes, but it syncs every file in the folder, instead of just one file.
Post by mb » Mon Apr 18, 2011 11:22 pm
Do you have the [x] Use cached folder tree option enabled in the Queue Action (Schedule Properties, Actions).
