The problem with encoding windows 1251
fav
Post by fav » Fri Jun 08, 2012 7:47 pm
The text redactor does not identify windows 1251 encoding automatically and it's not possible to set it by default. When saving file with that type of encoding some letters look like "???". Please, help us with the problem, because we have many files like these.
Dimitry
Re: The problem with encoding windows 1251
Post by Dimitry » Mon Jul 09, 2012 10:44 am
I need this feature too, and I wait for this.
Is not comfortable to change encoding every time with 3-4 clicks and make work in editor to hard
Do you plan to make this feature in the following times?
Setting default encoding for server, connection or in global settings will very help.
But the best solution is auto detection.
The same problem was here in russian support, and is not solved.
https://www.smartftp...ом-редакторе-ф/
