Visual Compare tweak...
Purgatory
Post by Purgatory » Mon Apr 11, 2011 6:34 pm
Hello. I've become accustomed to synchronized scrolling with my favourite compare program. It is really a time saver for me when comparing text or directories/files. In that program, both panes scroll simultaneously allowing me to quickly find results/issues.
Using SmartFTP's Visual Compare feature, one has to scroll through each pane to see the results (large directories are a chore with the current process). I think it would be better served to have synchronized scrolling added.
Any other users in agreement with this as a feature?
mb, is this something you would consider implementing as part of the Visual Compare feature?
Thank you for your time.
Purgatory
Re: Visual Compare tweak...
Post by Purgatory » Wed Apr 13, 2011 12:30 am
v4.0 Build 1179 x. April 2011
* Added auto scroll for Visual Compare
I bow to you.
jorjastandish
Post by jorjastandish » Mon Jul 18, 2011 12:57 am
Thanks for adding it!
