change delete file prompt
daXXon
Post by daXXon » Fri Nov 19, 2010 9:38 am
I like the idea of the delete prompt to prevent accidents, and I know you can disable it. My suggestion is to change the default focus away from "Don't ask me again." and set it to the Yes button. I like to be able to just hit the space bar, I believe it was like this in earlier versions.
I've been using SmartFTP for way too long, I'm just a robot going through the motions every day but for some reason that always trips me up.
Re: change delete file prompt
Post by mb » Sat Nov 20, 2010 4:54 am
You are right. It was a regression we have introduced. It will be fixed in the next build. Thanks for reporting.
