Installer: Desktop Icon Option
meisterkaiser
Post by meisterkaiser » Mon Aug 02, 2010 2:57 pm
just a small request:
I don't want no desktop icon. Would it be possible to add a checkbox in the installer?
Or a store a setting in the registry?
It's rather annoying having to remove the icon after *every single* update.
Re: Installer: Desktop Icon Option
Post by mb » Mon Aug 02, 2010 3:51 pm
There is currently no checkbox in the setup. Just delete the icon after the setup has completed.
meisterkaiser
Post by meisterkaiser » Mon Aug 02, 2010 5:17 pm
I know that there's no checkbox - that's why I'm requesting it :-)
I update frequently, so it's rather annoying having to remove the icon after *every single* update.
Turkdale
Post by Turkdale » Mon Sep 20, 2010 9:57 pm
And he's saying that you can delete the icon simply with 2 clicks ?
It's stupid to spend money to develop a checkbox for a desktop icon...
meisterkaiser
Post by meisterkaiser » Tue Sep 21, 2010 10:23 pm
Yes - I AM able to read ;-)
Usually I think it's a good idea to give the user choices with stuff like this and not force them into some rigid scheme (and SmartFTP does that with its flexible options). But you have a point here - I just didn't think a installer check box would be a big deal.
Now, if a 2 click icon removal is considered acceptable - then don't create a Desktop Icon at all.
Users who want it can actually create one themselves with about 2 clicks and need to do this ONLY ONCE (given that most likely their installation path will never change).
