rclick Drag folder menu: "Copy & Monitor"
hlince
Post by hlince » Sat Jun 19, 2010 2:49 pm
The idea is pretty direct, when right click dragging a file/folder from a local to a remote view you are presented with a menu with two options "Copy" and "Move" - Another very useful menu option would be "Copy & Monitor", this would eliminate the need to pause the queue, right click on the newly moved item, going to properties and enabling monitoring.
Other quick menu options could be Force Copy -> Copy everything, overwrite if necessary. and Synchronize Copy -> Copy following synchronization rules.
Thanks & Best Regards,
Howard
tascrafts
Re: rclick Drag folder menu: "Copy & Monitor"
Post by tascrafts » Sat Jul 03, 2010 4:22 pm
Hello,
I created a similar request here: https://www.smartftp.com/forums/index.ph ... -and-drop/
It's a nice feature which I really hope they add, but like your post and mine several months back, no reply has been made. Yet.
Let's hope for the best!
tas
Post by mb » Sun Aug 01, 2010 7:39 pm
There is a new feature in the latest version you may like:
•Transfer Queue: Added Monitor to extended context menu (hold the Shift key)
