Separate Details panel
Monkeyman
Post by Monkeyman » Sun May 09, 2010 10:44 am
Is is possible to make Details panel separate from Windows Explorer?
I mean, when you turn it off in SmartFTP, it turns off for whole system which is not good.
I do need it in my system, but don't in SmartFTP.
Re: Separate Details panel
Post by mb » Sun May 09, 2010 3:31 pm
I'm sorry but I do not understand your question.
Monkeyman
Post by Monkeyman » Sun May 09, 2010 4:01 pm
In SmartFTP you have View -> Panels -> Details item which turns on/off a details panel. It shows some info about file or folder.
Windows Explorer has the same panel on the bottom of the window (Organize -> Layout -> Details pane).
If I turn off details panel in SmartFTP, then it'll turn off in Windows Explorer as well.
At least, such as the behavior in Windows 7.
Now you got me?
Post by mb » Sun May 09, 2010 4:44 pm
The setting in SmartFTP does not affect the setting in Windows Explorer.
Monkeyman
Post by Monkeyman » Sun May 09, 2010 5:03 pm
So you probably think I am an idiot and just messing around? :-)
Trust me it DOES affect. I turn off details panel in SmartFTP, the same panel turns off in Windows Explorer.
You may want to test in on Windows 7 if you didn't.
Post by mb » Sun May 09, 2010 8:06 pm
Yes you are right, on Windows 7 the control always saves its state into the registry without our control. Unlike in Windows Vista, Microsoft doesn't give us a chance to provide our own registry key.
Monkeyman
Post by Monkeyman » Sun May 09, 2010 8:15 pm
So is it possible to fix this issue?
Post by mb » Sun May 09, 2010 8:26 pm
It is not a bug, the control just has no documented way to specify the registry key. But there is most likely an undocumented method as this was the case on Windows Vista.
Monkeyman
Post by Monkeyman » Sun May 09, 2010 8:29 pm
OK, I guess you'll keep this in mind and find the way to make it work on Windows 7.
This is not big deal, just a little annoyance.
Post by mb » Sun May 09, 2010 9:11 pm
The new build will take care of this problem.
