Save sources/destinations for Multi-upload on exit
danifer
Post by danifer » Mon Aug 25, 2008 2:20 pm
Wouldn't it be neat if SmartFTP could save the added sources/destinations for multi-upload?
I'm using the same destinations everyday, just different sources.
Thanks!
Daniel
Re: Save sources/destinations for Multi-upload on exit
Post by mb » Mon Aug 25, 2008 4:30 pm
Hello Daniel ..
Yes something like this is planned. Do you want to save the source/destination individiually or together?
danifer
Post by danifer » Tue Aug 26, 2008 8:44 am
Personally, I would like to see that they are left (saved) as they were. Both sources and destinations.
Daniel
Hello Daniel ..
Post by mb » Wed Aug 27, 2008 4:27 am
Hmm
Isn't this already the case for you? The source/destination contents are automatically saved to a .dat file located in the %AppData%\SmartFTP\Client 2.0\ folder
danifer
Post by danifer » Wed Aug 27, 2008 1:38 pm
Oh - I see now that they are. But, Ive experienced a lot of crashes during multi-uploads and then I've always lost the source/destinations. Are they only written to disk on a normal exit? Not continuously?
I have to get that debug thingy you mentioned.
Hmm
Post by mb » Wed Aug 27, 2008 3:31 pm
Yes they are only saved on a normal exit.
danifer
Post by danifer » Wed Aug 27, 2008 5:45 pm
It wouldn't really hurt the performance if you wrote them to file upon adding/removing , or would it? That would hlp alot as I see SmartFTP is not currently as stable as it should be .
Btw. Thanks for a great support!
Post by mb » Wed Aug 27, 2008 5:56 pm
I would rather prefer to take a look at the crash dump why SmartFTP is crashing. Do you think it is possible that you can send us a crash dump?
danifer
Post by danifer » Thu Aug 28, 2008 9:35 am
Installaling the debug software now ...Will come back with a dump soon ...
danifer
Post by danifer » Thu Aug 28, 2008 10:04 am
