Metalink support
0
No votes
Total votes: 0
twanj
Metalink support
Post by twanj » Fri Jan 19, 2007 5:33 pm
Re: Metalink support
Post by mb » Fri Jan 19, 2007 11:24 pm
I've quickly wrote an importer for the metalink v3 format. To test it download the latest version from
Then in the Transfer Queue tab, click on the Add button. Then select the "*.metalink" file. The import adds the files to the Temporary Queue because they don't have a destination yet.
The metalink format is not very well designed for the FTP protocol. For example it doesn't support FTP over SSL etc.
eyebex
Post by eyebex » Fri Jan 19, 2007 11:54 pm
As I understand it, it does not make much sense to support Metalink in SmartFTP, because SmartFTP cannot (yet) download a single file from multiple servers, and that's the main purpose of Metalink: To list mirrors of a single file.
So it's important to understand SmartFTP will not parse all URLs listed in a <resources> section, but only add one of them (the first FTP URL). It only adds another URL if it occurs in a different <files> section. Put simply: Currently only adding one URL per <resources> section is supported.
twanj
Post by twanj » Sat Jan 20, 2007 1:59 am
Post by mb » Sun Jan 21, 2007 12:26 am
>What do you need besides <url type="ftps">? Since metalinks are for listing the types that client programs support, it will be easy enough to add.
I think this should be sufficient. Right now SmartFTP will try to parse the URL if the type is set to "ftp" or "ftps". If the URL starts with "ftps://" SmartFTP assumes it's FTP over SSL.
>Just curious, I'm not familiar w/ XMD5 or XSHA which I see SmartFTP supports. I guess these are FTP server commands similar to Content-MD5 headers from web servers?
Yes that's correct. The client sends XMD5 <file> and the server returns the MD5 hash value. Unfortunately FTP servers under *nix do not support such features. However most FTP servers on MS Windows do.
>Will SmartFTP be able to use the MD5 or SHA1 checksums listed in metalinks to verify the downloads (or does it already)?
Yep the latest version (2.0.1001.26) does now ;-) Please give it a try.
twanj
Post by twanj » Sun Jan 21, 2007 7:28 pm
Post by mb » Mon Jan 22, 2007 6:25 pm
Thank you for the additional information on the partial checksums. However I think we will delay the support for partial checksums until we have the multi-part dowload feature ready.
I would appreciate if you could let me know about any future additions to the Metalink format which may benefit an FTP client like ours.
Best Regards,
twanj
Post by twanj » Tue Feb 06, 2007 6:06 pm
I will. If you see any other areas of Metalink that need improvement, feedback is good
That will be great if you add multi-part downloads! It can really speed up downloads quite a bit.
twanj
Post by twanj » Tue Feb 27, 2007 6:19 pm
Here are some recent posts on metalink. The first one is particularly good.
http://www.geospatialsemanticweb.com/20 ... -downloads
http://slashdot.org/article.pl?sid=07/02/25/144209
Post by mb » Tue Feb 27, 2007 9:08 pm
Thank you for the updates :-)
