Global Queue > Select Folder
vrapp
Post by vrapp » Sat Aug 16, 2003 2:47 am
The destination in Global Queue is not a diretory but file path. However, if I open Properties of a queue item and then click "select folder" icon on the right from the destination, it opens "browse for folder" dialog. If I select a folder, its name is written as the destination file name. Then when SmartFTP will try do download the file and give it this name (which is the name of an existing directory I selected), this will result in "system error".
Louie
Re: Global Queue > Select Folder
Post by Louie » Sat Aug 16, 2003 3:29 am
Hi !
I can reproduce the problem. It seems to not be adding the
file name to the path, when using the "Select Folder" option.
This will be fixed in a dev. build update, thank you for reporting.
Post by mb » Tue Aug 19, 2003 1:19 am
Hi ..
The problem has been fixed in the latest developer build.
