SSL connection is not interrupted after clicking NO in the Verify Certificate Dialog Box
Artem
Post by Artem » Thu Nov 22, 2007 10:49 am
Hallo,
I found a bug in SmartFTP Client 2.5.1008:
When I am visiting a FTPS Server (FTP over SSL Explicit) and the certificate fails the validation, I get the "Verify Certificate" Dialog Box.
Now it makes no difference whatever I select. Clicking on yes and no have the same result:
SmartFTP is connecting to the server.
This should no happen when clicking on no.
Re: SSL connection is not interrupted after clicking NO in the Verify Certificate Dialog Box
Post by mb » Fri Nov 23, 2007 5:05 am
Thank you for your bug report. I have found and fixed the bug. Patch will be available in the next build.
I will post here as soon as it's available.
mat
Post by mb » Tue Nov 27, 2007 12:21 pm
Please try again with the latest version:
The bug has been fixed.
Artem
Post by Artem » Tue Nov 27, 2007 1:20 pm
ok, thanks, it works now.
Regards, Artem
Post by mb » Tue Nov 27, 2007 1:29 pm
Thanks for getting back to us. Did you have a chance to look at the other post regarding the cert verification?
Artem
Post by Artem » Tue Nov 27, 2007 4:48 pm
no, sorry, lets see if I have some time to morrow, so I can run some more test.
I will write you as soon as I have more results.
Regards, Artem
