Double click on images won't open, force to use open with
Mathachew
Post by Mathachew » Sun Nov 18, 2007 2:19 am
As the title says, anytime I want to look at an image on my PC, double clicking does nothing, forcing me to right click, go to Open With and select the default program, Windows Photo Gallery. To my knowledge, this problem only exists on Vista. I'm not sure if the default program makes a difference or not, but mine is the original default, Windows Photo Gallery. Here are my system specs:
 (Build 6000)
CPU Speed		 : 2133 MHz
Total Memory	  : 2045 MB
Free Memory	   :  871 MB
Version		   : 2.5.1008.9
Time Stamp		: 2007-11-11 20:16:59
Platform		  : x64
sfFTPLib.dll	  : 1.5.11.6
sfFavorites.dll   : 1.0.4.9
SmartHook.dll	 : 1.0.2.2
SmartFTP.exe	  : 2.5.1008.9
Version		   : 7.0.6000.16546
Winsock		   : 2.2
Thanks!
Re: Double click on images won't open, force to use open with
Post by mb » Sun Nov 18, 2007 3:05 am
Bug confirmed. Working on a fix.
Thank you for posting.
yli
Post by yli » Sun Nov 18, 2007 9:30 am
Post by mb » Sun Nov 18, 2007 10:10 am
In this case it seems we already looked into it and figured out that we can't "fix" it.
Nevertheless we will give it another try.
yli
Post by yli » Sun Nov 18, 2007 10:41 am
ok ...try to fix
Post by mb » Sun Nov 18, 2007 11:00 am
We just looked into it and the shellview control asks for an interface which is unknown (not documented). As a result the interface cannot be found and the caller (not SmartFTP) crashes for some reason.
yli
Post by yli » Sun Nov 18, 2007 11:06 am
weird...
ask Microsoft how to do this API...
Post by mb » Wed Nov 21, 2007 2:00 am
Workaround in the latest version (.16):
We are handling the double click action ourselves now.
yli
Post by yli » Wed Nov 21, 2007 8:21 pm
thanks
bug fixed too in Version : 2.5.1008.15 x64
