Thunderbird conflict
sflorg
Post by sflorg » Fri Oct 05, 2007 12:58 pm
When Thunderbird e-mail client and SmartFTP (latest Beta version)
are both minimized and Thundirbird is brought up... So will SmartFTP, but not visa versa.
Both in system tray, on XP
Interesting bug.
Heidi-Ann Kennedy
Scientific Frontline
Re: Thunderbird conflict
Post by mb » Fri Oct 05, 2007 7:46 pm
I'm unable to reproduce this. Tested with Thunderbird 2.0.0.6 and the latest version of SmartFTP.
Are you restoring Thunderbird from the systray or the task bar?
What theme are you using in SmartFTP?
Can you create a movie showing the problem?
sflorg
Post by sflorg » Sat Oct 06, 2007 2:16 pm
Yes TB is minimized in System tray using two ext's to do such... They are "minimize to tray" and "minimize to tray enhancer"
Smart FTP default theme, TB theme Pitch Dark.
TB Ver. 2.0.0.6 FTP Ver. 2.5.1006
This is the only Ver of Smart FTP that ever did it.
I will work on animation later and post a URL
sflorg
Post by sflorg » Sat Oct 06, 2007 3:00 pm
Post by mb » Sat Oct 06, 2007 4:34 pm
The problem is as following:
1. Thunderbird restores the window and removes the systray icon on the MouseDown message.
2. The SmartFTP tray icon receives the MouseUp message because Thunderbird has it's icon removed in 1
3. SmartFTP restores the main window as well
Previously SmartFTP did restore the window on the MouseDown message as well. But we have changed this recently to avoid conflicts as above.
See: https://www.smartftp.com/forums/index.ph ... entry40653
Conclusion
In my opinion Thunderbird should remove the systray icon on the MouseUp message instead of the MouseDown message. You may want to report the problem to developer of the Thunderbird addon http://codefisher.org/projects/minimize ... y_enhancer.
sflorg
Post by sflorg » Sun Oct 07, 2007 9:23 am
Post by mb » Tue Oct 09, 2007 4:36 pm
After the review of the Mozilla "Minimize to Tray" Extension (http://minimizetotray.mozdev.org/) I realized that my previous analysis was wrong. The extension uses the correct event (EVENT_MOUSEUP_LEFT) to restore the window. However if you have the "Require a double click to restore from tray" option in the "Minimize to Tray" extension enabled SmartFTP receives a mouse up event and restores the window as well. I believe the double click should be avoided when the icon is removed from the systray as the next icon in the systray will receive the mouse down event. This is very likely not the intended behavior.
To workaround the problem, disable the "Require a double click to restore from tray" in the settings of the addon/extension in Thunderbird/FireFox (Menu: Tools->Add-ons). To restore the window use a single left click instead of a double click or you will end up with the same problem again.
Please let me know if this helps.
sflorg
Post by sflorg » Mon Oct 15, 2007 1:03 pm
Worked like a charm...
As always, outstanding support for an outstanding product...
One just can't fail with SmartFTP
Heidi-Ann Kennedy
Director
