Windows Taskbar disappears
I've just downloaded version 2.5.1006.15, but have found that, when using the Office 2007 themes, the windows taskbar will not popup, whereas it does with all the other themes.
I would like to use the Office 2007 theme, but I can't until this problem is fixed.
Debbie
Debbie
- Contact:
Re: Windows Taskbar disappears
I have no problem with the Office 2007 on Vista. What operating system are you using?
I have the same problem.
Windows XP SP2 with the Taskbar set to Auto-Hide.
Hi mb,
Sorry for the delay in replying, but I didn't get the notification of your post. I'm also using Windows XP SP2 with the taslbar on auto-hide.
Debbie
Debbie
- Contact:
Bug confirmed. It will be fixed in a future version.
Thank you. If it is a codejock issue, you might still get the fix in the next release thats coming out next week.
- Contact:
That was actually our plan
Let's hope they have adressed the problem.
- Contact:
The latest update from Codejock didn't fix the problem with SmartFTP. Could you please try to test it with the "Gallery Sample" application from Codejock?
http://www.codejock.com/downloads/sampl ... ndbars.asp
- Contact:
The problem still persists. I have reported it again to Codejock.
