Cisco VPN Client Cause SmartFTP problems
Sorbukar
Post by Sorbukar » Thu Aug 02, 2007 6:57 pm
Interesting little problem using SmartFTP to move files to a server behind a VPN. Using Cisco VPN Client 5.0.00.0340 (the one that works on Vista)
Under Windows XP:
Start VPN Client
Connect to VPN
Start SmartFTP - does initial dialog and then nothing
Start SmartFTP again - seems to continue from where it left off - works fine after that
Under Windows Vista:
Start VPN Client
Connect to VPN
Start SmartFTP - does nothing
Workaround (for both)
Start SmartFTP
Start VPN Client
Works fine.
Doesn't seem to affect other pieces of software (e.g. puTTY, MySQL admin tools).
Re: Cisco VPN Client Cause SmartFTP problems
Post by mb » Thu Aug 02, 2007 7:02 pm
Then post the system information from the menu: Help -> About.
Is the SmartFTP.exe still in the process list or does it terminate?
