.bad extrension
oil
.bad extrension
Post by oil » Fri Jul 27, 2007 5:12 pm
i used BPFTP since years, and due a friend needed a ftp program which can limit speed, i made a quick googling action and smart FTP came up, when i
oil
Re: .bad extrension
Post by oil » Fri Jul 27, 2007 5:17 pm
also
is there a option to for sFTP not to create those .bad files
or
easy remove all the .bad files which has been created?
Aokromes
Re: .bad extrension
Post by Aokromes » Fri Jul 27, 2007 9:39 pm
Hi. the .bad files are because server configuration, for easy remove, sort by extension and select al the .bad files and delete.
Re: .bad extrension
Post by mb » Sat Jul 28, 2007 9:43 am
Please post the system information you can find under the menu: Help -> About dialog.
And please post the complete log as well. Thank you.
oil
Re: .bad extrension
Post by oil » Tue Jul 31, 2007 9:36 am
System Info:
Service Pack 2 (Build 2600)
CPU Speed : 2211 MHz
Total Memory : 1023 MB
Free Memory : 435 MB
Version : 2.5.1006.12
Time Stamp : 2007-07-26 19:44:38
sfFTPLib.dll : 1.5.9.26
sfFavorites.dll : 1.0.2.12
SmartHook.dll : 1.0.2.2
SmartFTP.exe : 2.5.1006.12
Version : 7.0.5730.11
the part of the log where the files should be transfered
but it created only .bad files:
[11:34:13] PASV
[11:34:13] 227 Entering Passive Mode (69,22,133,7,196,102)
[11:34:13] Opening data connection to 69.22.133.7 Port: 50278
[11:34:13] LIST -aL
[11:34:14] 150 Opening ASCII mode data connection for '/bin/ls'.
[11:34:14] 226 Transfer complete.
[11:34:14] 285 bytes transferred. (1,37 KB/s) (203 ms)
Re: .bad extrension
Post by mb » Tue Jul 31, 2007 2:26 pm
Bug fixed. Please try it again with the latest version (.14)
oil
Re: .bad extrension
Post by oil » Wed Aug 01, 2007 10:02 pm
