TortoiseSVN layer icons on files and folders disappaer in SmartFTP
hoaxer
Post by hoaxer » Tue May 29, 2007 9:43 am
I use SmartFTP v2.0.1200 on Windows XP SP2 and Tortoise SVN 1.4.3.8645
Sometimes when I start SmartFTP the layer icons on files and folders are disappaered on some SVN directories, refreshing don't help.
Sometimes everything is OK, but not always
As in the screenshot you can see the folders on top don't have svn icons but the icons on my other drive everything is OK
The bug came up since using SmartFTP v2.0.1000
Aokromes
Re: TortoiseSVN layer icons on files and folders disappaer in SmartFTP
Post by Aokromes » Tue May 29, 2007 10:03 am
Hi, SmartFTP 2.0 is not longer supported, update to the last 2.5 build from my signature and test if the bug is gone.
hoaxer
Post by hoaxer » Tue May 29, 2007 2:09 pm
The bug is not gone, but it's possible a TortoiseSVN bug (http://svn.haxx.se/tsvnusers/archive-2007-05/0064.shtml)
the only difference with the TortoiseSVN bug is that it affects Windows explorer (and that is not in my case)
but the solution (restart TSVNCache.exe) works.
