Remote browser doesn't list all folders
roland.moelle
Post by roland.moelle » Fri Mar 30, 2007 2:00 pm
I'm using SmartFTP Client from time to time to administer our web server's content at university which is running under HP-UX 10. After I did an update to SmartFTP Release 2.5.1002. I found that the remote browser doesn't show all folders anymore. A raw listing contains the correct content. I tried different PCs with different Client OS (2K and XP) and also the beta release (2.5.1005): It's always the same problem . When using a previously downloaded and installed version of SmartFTP Release 1.0.979 everything works fine for me? I think I already used 2.x releases that worked fine (at least in this point). I can also change to missing folders sucessfully, but there's no content displayed. Is there/will there be a fix available? I was searching the forum, but didn't discover anything.
Re: Remote browser doesn't list all folders
Post by mb » Fri Mar 30, 2007 2:53 pm
Dear Roland ...
Please post the following addtional information:
1. Log of your FTP session
2. Raw Directory listing
roland.moelle
Post by roland.moelle » Mon Apr 02, 2007 9:54 am
Hello Mat,
this is the Log:
[11:24:26] SmartFTP v2.5.1005.6
[11:24:27] Resolving host name "ftp.ltm.mw.tu-muenchen.de"
[11:24:27] Connecting to 129.187.64.105 Port: 21
[11:24:28] Connected to ftp.ltm.mw.tu-muenchen.de.
[11:24:28] 220 hp5 FTP server (Version 1.7.212.3 Wed Jul 14 10:24:05 GMT 1999) ready.
[11:24:28] USER admin
[11:24:28] 331 Password required for admin.
[11:24:28] PASS (hidden)
[11:24:28] 230 User admin logged in.
[11:24:28] SYST
[11:24:28] 215 UNIX Type: L8
[11:24:28] Detected Server Type: UNIX
[11:24:28] FEAT
[11:24:28] 500 'FEAT': command not understood.
[11:24:28] TYPE I
[11:24:28] 200 Type set to I.
[11:24:28] REST 0
[11:24:28] 350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer.
[11:24:28] PWD
[11:24:28] 257 "/home/admin" is current directory.
[11:24:28] CWD /home/html
[11:24:28] 250 CWD command successful.
[11:24:28] PWD
[11:24:28] 257 "/home/html" is current directory.
[11:24:28] TYPE A
[11:24:28] 200 Type set to A.
[11:24:28] PASV
[11:24:28] 227 Entering Passive Mode (129,187,64,105,6,85)
[11:24:28] Opening data connection to 129.187.64.105 Port: 1621
[11:24:28] LIST -aL
[11:24:28] 150 Opening ASCII mode data connection for /usr/bin/ls.
[11:24:29] 226 Transfer complete.
[11:24:29] 15027 bytes transferred. (24,7 KB/s) (594 ms)
[11:25:04] PASV
[11:25:04] 227 Entering Passive Mode (129,187,64,105,6,86)
[11:25:04] Opening data connection to 129.187.64.105 Port: 1622
[11:25:04] LIST -aL
[11:25:04] 150 Opening ASCII mode data connection for /usr/bin/ls.
[11:25:04] 226 Transfer complete.
[11:25:04] 15027 bytes transferred. (33,5 KB/s) (438 ms)
[11:25:55] NOOP
[11:25:55] 200 NOOP command successful.
and the RAW listing:
Only the following folders are beeing displayed:
alt
ciw
g
ltm
seminar
skripten
spk
stud
umfrage
vdi-meg
As you can see from the raw listing, there are much more folders (for example "ltsim" is the one I'm working with at the moment):
-rwxrwxr-x   1 www		www		  18786  2. Juli 2003 abstr.html
-rwxrwxr-x   1 www		www		2367916  3. Jan. 2002 access_log
-rwxrwxr-x   1 www		www		  22528 13. Jan. 2003 aktuell.html
-rwxrwxr-x   1 www		www		   1728 14. Jan. 2002 aliases.html
drwxrwxr-x   9 www		www		   3072  2. Jan. 2002 alt
-rwxrwxr-x   1 www		www		  19480  2. Juli 2003 anderl.html
-rwxrwxr-x   1 www		www		  18706  3. Jan. 2002 anduni.html
-rwxrwxr-x   1 www		www		  19127  2. Juli 2003 ant.html
-rwxrwxr-x   1 www		www		   2151  3. Jan. 2002 aushang1.html
-rwxrwxr-x   1 www		www		  24221  3. Jan. 2002 autom.html
-rwxrwxr-x   1 www		www		  18893  2. Juli 2003 balthes.html
-rwxrwxr-x   1 www		www		  18727  3. Jan. 2002 bauer.html
-rwxrwxr-x   1 www		www		  23562  3. Jan. 2002 bf.html
-rwxrwxr-x   1 www		www		  18900  2. Juli 2003 biechl.html
-rwxrwxr-x   1 www		www		  19168  2. Juli 2003 binder.html
-rwxrwxr-x   1 www		www		  35372  3. Jan. 2002 biooele.pdf
-rwxrwxr-x   1 www		www		   2289  3. Jan. 2002 BIOOEL.HTM
-rwxrwxr-x   1 www		www		  18570  2. Juli 2003 boehler.html
-rwxrwxr-x   1 www		www		   2513  3. Jan. 2002 brenning.html
-rwxrwxr-x   1 www		www		  19198  2. Juli 2003 brenn.html
-rwxrwxr-x   1 www		www		  18504  3. Jan. 2002 brueckl.html
-rwxrwxr-x   1 www		www			437  3. Jan. 2002 buro.html
drwxrwxr-x   2 www		www		   1024  9. Juli 1998 ciw
-rwxrwxr-x   1 www		www		  30918  3. Jan. 2002 CVT.HTM
-rwxrwxr-x   1 www		www		  19132  2. Juli 2003 dar.html
-rwxrwxr-x   1 www		www		  77214  3. Jan. 2002 dasa_dru.html
-rwxrwxr-x   1 www		www		  32133  3. Jan. 2002 dasa_ue.html
-rwxrwxr-x   1 www		www		 106208  2. Juli 2003 da.html
-rwxrwxr-x   1 www		www		 201233  3. Jan. 2002 error_log
-rwxrwxr-x   1 www		www			464  3. Jan. 2002 fakul.html
-rwxrwxr-x   1 www		www			964 28. Juni 2002 formate.css
-rwxrwxr-x   1 www		www		  25261  3. Jan. 2002 forsch.html
-rwxrwxr-x   1 www		www		   1806  3. Jan. 2002 frame.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_10.html
-rwxrwxr-x   1 www		www		   1365  3. Jan. 2002 frame_11.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_12.html
-rwxrwxr-x   1 www		www		   1369  3. Jan. 2002 frame_13.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_14.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_15.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_16.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_17.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_18.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_19.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_1.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_20.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_21.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_22.html
-rwxrwxr-x   1 www		www		   1365  3. Jan. 2002 frame_23.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_24.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_25.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_26.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_27.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_28.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_29.html
-rwxrwxr-x   1 www		www		   1366  3. Jan. 2002 frame_2.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_30.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_31.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_32.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_33.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_34.html
-rwxrwxr-x   1 www		www		   1363  3. Jan. 2002 frame_35.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_36.html
-rwxrwxr-x   1 www		www		   1366  3. Jan. 2002 frame_37.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_38.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_39.html
-rwxrwxr-x   1 www		www		   1365  3. Jan. 2002 frame_3.html
-rwxrwxr-x   1 www		www		   1324  3. Jan. 2002 frame_40.html
-rwxrwxr-x   1 www		www		   1365  3. Jan. 2002 frame_41.html
-rwxrwxr-x   1 www		www		   1324 14. Jan. 2002 frame_42.html
-rwxrwxr-x   1 www		www		   1362  3. Jan. 2002 frame_4.html
-rwxrwxr-x   1 www		www		   1366  3. Jan. 2002 frame_5.html
-rwxrwxr-x   1 www		www		   1368  3. Jan. 2002 frame_6.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_7.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_8.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_9.html
-rwxrwxr-x   1 www		www		   1362  3. Jan. 2002 frame_da.html
-rwxrwxr-x   1 www		www		   1367  3. Jan. 2002 frame_lit.html
-rwxrwxr-x   1 www		www		   1364  3. Jan. 2002 frame_marb.html
-rwxrwxr-x   1 www		www		  19254  2. Juli 2003 freim.html
drwxrwxr-x   2 www		www		   5120 13. Aug. 2002 g
-rwxrwxr-x   1 www		www		  18501  3. Jan. 2002 grad.html
-rwxrwxr-x   1 www		www		  52176  5. M
Last edited by roland.moelle on Mon Apr 02, 2007 10:29 am, edited 1 time in total.
roland.moelle
Post by roland.moelle » Mon Apr 02, 2007 9:59 am
PS: This is the log from my old PC running SmartFTP 1.0.979, which is doing fine in this concern:
Resolving host name ftp.ltm.mw.tu-muenchen.de...
Connecting to (ftp.ltm.mw.tu-muenchen.de) -> IP: 129.187.64.105 PORT: 21
Connected to (ftp.ltm.mw.tu-muenchen.de) -> Time = 0ms
USER admin
PASS (hidden)
SYST
215 UNIX Type: L8
FEAT
REST 100
350 Restarting at 100. Send STORE or RETRIEVE to initiate transfer.
REST 0
PWD
CWD /home/html
PWD
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (129,187,64,105,6,87)
Opening data connection IP: 129,187,64,105,6,87 PORT: 1623.
LIST -aL
15027 bytes received successfully. (14.67 KB/s) (00:00:01).
Thanks a lot,
Roland
Post by mb » Mon Apr 02, 2007 2:41 pm
Thank you. The problem has been fixed in the latest version. The problem was with the M
roland.moelle
Post by roland.moelle » Tue Apr 03, 2007 11:45 am
Hi Mat,
the updated version works fine now - thanks a lot!
Roland
