Queue transfer : in the destination, nothing but folder "SFTPDROP"
olivier.pons
Post by olivier.pons » Wed Mar 07, 2007 10:19 am
Sometimes (seldom), when I try to transfer the files, with the 'Q' option clicked, I drag'n drop from my ftp-source to my local folder destination and there's only a folder named SFTPDROP that is created.
The only way to get my transfer to work is to quit then re-launch Smartftp.
This is under WinXP SP2 / latest patches, 4Go RAM, 320 Gb hard drive, and the ftp is a local connexion (= very fast).
It just happened twice, but this is really annoying.
This problem does happen even with only one file.
Note : I'm always using the drag'n drop feature to transfer files, no other way.
Re: Queue transfer : in the destination, nothing but folder "SFTPDROP"
Post by mb » Wed Mar 07, 2007 12:19 pm
Is there any way you can reproduce the problem in a reasonable time span? If it only happens sporadically it's very hard to find a solution for it.
secarica
Post by secarica » Mon Apr 16, 2007 1:11 am
I cannot transfer nothing from remote server to local desktop, because of the same SFTPDROP folder thing. The only way I found for transferring is to rightclick on the desired item and explicitly specify the download destination folder, but this is too annoying to be used.
I installed Smat FTP fresh on a fresh installed WinXP.
The file type is of no importance.
Passive or not makes no difference.
I noticed no problem in file uploading.
Cristi
Post by mb » Mon Apr 16, 2007 8:46 am
The correct way to install SmartFTP is as following:
1. Install SmartFTP from
2. It may be necessary to restart your computer
secarica
Post by secarica » Mon Apr 16, 2007 6:13 pm
The problem has gone after system restart. I'm on a notebook and usually I don't shut down or restart the system until explicitly requested to do so.
As for file version, I downloaded it from this site less than 24 hours than my previous post. The file I have says version 2.5.1005.22 and the length is 3.779.120 bytes.
Thank you,
Cristi
Post by mb » Mon Apr 16, 2007 7:11 pm
For the CopyHook (SmartHook.dll) to work correctly the Windows Explorer (Explorer.exe) needs to be restarted. Unfortunately there is no other solution. Microsoft doesn't provide the necessary API to reload/refresh the CopyHook shell handlers.
W13
Post by W13 » Sun Jul 08, 2007 9:41 pm
I can confirm.
I just installed on Vista... and everytime I drag and drop a file from FTP onto my desktop, all I get is that SFTDROP folder (which is empty)
Microsoft Windows Vista Home Premium Edition
 (Build 6000)
CPU Speed		 : 1729 MHz
Total Memory	  : 1013 MB
Free Memory	   :  349 MB
Version		   : 2.5.1006.6
Time Stamp		: 2007-06-30 00:31:40
Platform		  : x86
sfFTPLib.dll	  : 1.5.9.24
sfFavorites.dll   : 1.0.2.6
SmartHook.dll	 : 1.0.2.2
SmartFTP.exe	  : 2.5.1006.6
Version		   : 7.0.6000.16473
Winsock		   : 2.2
W13
Post by W13 » Sun Jul 08, 2007 10:02 pm
OK- I rebooted computer- and now it works.
