Vista?
lbembry
Vista?
Post by lbembry » Tue Feb 27, 2007 11:25 pm
I recently purchased a laptop with Windows Vista. I have been using SmartFTP for tranferring files for my courses on my desktop which has XP with no problem. I have manipulated the firewall and had no luck, with the log looking like this:
[17:59:32] SmartFTP v2.5.1004.7
[17:59:32] Resolving host name "egrweb2.mercer.edu"
[17:59:32] Connecting to 209.172.225.94 Port: 2111
[17:59:32] Connected to egrweb2.mercer.edu.
[17:59:32] 220 webdev Microsoft FTP Service (Version 5.0).
[17:59:32] USER MERCER\sse553-07s
[17:59:32] Cannot login waiting to retry (30s)...
[17:59:32] Server closed connection
Does this problem have something to do with Vista? Can you help?
Re: Vista?
Post by mb » Wed Feb 28, 2007 4:24 am
From the log it looks like your username is not correct.
lbembry
Re: Vista?
Post by lbembry » Wed Feb 28, 2007 4:40 am
I don't think that's the problem. I also have the software installed on my desktop. Here is the successful login of that account on my desktop.
[23:24:50] SmartFTP v2.0.1002.0
[23:24:53] Resolving host name "egrweb2.mercer.edu"
[23:24:53] Connecting to 209.172.225.94 Port: 2111
[23:24:53] Connected to egrweb2.mercer.edu.
[23:24:53] 220 webdev Microsoft FTP Service (Version 5.0).
[23:24:53] USER MERCER\sse553-07s
[23:24:53] 331 Password required for MERCER\sse553-07s.
[23:24:53] PASS (hidden)
[23:24:53] 230 User MERCER\sse553-07s logged in.
[23:24:53] SYST
[23:24:53] 215 Windows_NT version 5.0
[23:24:53] Detected Server Type: Windows NT
[23:24:53] FEAT
[23:24:53] 500 'FEAT': command not understood
[23:24:53] TYPE I
[23:24:53] 200 Type set to I.
[23:24:53] REST 0
[23:24:53] 350 Restarting at 0.
[23:24:53] PWD
[23:24:53] 257 "/sse553-07s" is current directory.
[23:24:53] TYPE A
[23:24:53] 200 Type set to A.
[23:24:53] PASV
[23:24:53] 227 Entering Passive Mode (209,172,225,94,16,108).
[23:24:53] Opening data connection to 209.172.225.94 Port: 4204
[23:24:53] LIST -aL
[23:24:53] 125 Data connection already open; Transfer starting.
[23:24:53] 271 bytes transferred. (8.53 KB/s) (31 ms)
[23:24:53] 226 Transfer complete.
[23:25:44] NOOP
[23:25:44] 200 NOOP command successful.
Re: Vista?
Post by mb » Wed Feb 28, 2007 4:47 am
The problem might be caused by another application (antivirus, software firewall) which is hooking into the connection. It's unlikely that the problem originates from SmartFTP.
Try to uninstall all applications in question and try again.
lbembry
Re: Vista?
Post by lbembry » Wed Feb 28, 2007 5:25 am
I have disabled my firewall (McAfee & Windows), virus protection and anti-spyware software and no difference. Shouldn't SmartFTP work when I disable these if this is the problem? I was wondering if it was a Vista setting that was effecting the connectivity.
Re: Vista?
Post by mb » Wed Feb 28, 2007 5:33 am
Try to uninstall the McAfee product and try again. Microsoft products (e.g. Windows Firewall) usually do not cause any problems.
