SmartFTP will not start - EVP_PKEY_get_raw_private_key
EdRobichaud
Post by EdRobichaud » Fri Jul 20, 2018 7:29 pm
After updating to ver 9.2601, the program will not start - see error msg below:
"The procedure entry point EVP_PKEY_get_raw_private_key could not be located in the dynamic link library D:\Program Files\SmartFTP Client\FTPlib.dll. "
Unable to contact support from inside program, as program will not run. Tried re-installing, but no help.
EdRobichaud
Re: SmartFTP will not start
Post by EdRobichaud » Fri Jul 20, 2018 7:43 pm
OK, 3 reinstall & repairs got it to start & run
Post by mb » Wed Jul 25, 2018 9:11 pm
If anyone else faces the same problem:
- Uninstall
- Restart
- Install the latest version from the website
