When uploading files to Google Drive, speed is stuck at 75Mbps.
Gurupam
Post by Gurupam » Wed Jan 04, 2017 12:13 pm
Download speed is fine, but upload speed will not go up at 75Mbps anymore.
I don't know what the problem is.
Re: When uploading files to Google Drive, speed is stuck at 75Mbps.
Post by mb » Wed Jan 04, 2017 1:36 pm
It's normal. Also your speed tests uses different units (Si: Mbit/s = 1'000'000 bytes/s). In SmartFTP 1 MByte is 1024*1024 bytes.
Gurupam
Post by Gurupam » Wed Jan 04, 2017 2:18 pm
mb wrote: It's normal. Also your speed tests uses different units (Si: Mbit/s = 1'000'000 bytes/s). In SmartFTP 1 MByte is 1024*1024 bytes.
I think it's not normal.
Uploading with C gives 95Mbps (11MB/s) speed but SmartFTP gives only 75Mbps (9.0MB/s) speed.
I checked in Task Manager.
Post by mb » Wed Jan 04, 2017 2:20 pm
SmartFTP transfers the files as fast as possible. There is nothing that limits the transfer speed in the client.
Please contact support for further assistance: menu: File - Help - Request Support. Thank you.
