Problem with scheduling task in windows 10
Thestag
Post by Thestag » Mon Feb 08, 2016 8:51 pm
I have smartftp working well with task scheduler in Windows server 2003 for years. And now I just bought the ultimate edition for my news Windows 10 and try to Schedule a ftp job. The job appears in the scheduler tab but when I try to run the  task  , its start for a second stop with error code acces denied. I have try with high privilege option too.
I can do the same upload manualy and works well (same local user and remote user ..)
Its was so easy in Windows server 2003... but with Windows 10 .......
Any suggestion ?
Re: Problem with scheduling task in windows 10
Post by mb » Mon Feb 08, 2016 9:16 pm
Thestag
Post by Thestag » Mon Feb 08, 2016 10:52 pm
Thanks , I forgot about the right KB: How to give a user Log on as a batch job rights...
when I was trying with interactive mode I have the acces denied problem too but my problem was:
 when you try to start the smartftp task with system then a process of smartftp still in memory.. Then after If you modify the task to run with the user, and run the task again .. Then smartftp start a new instance each time with the acces denied error. To solve the problem you need to kill the smartftp process start with system....
