Olympus ORF files not transferring
judyn
Post by judyn » Fri Jan 22, 2016 1:34 am
I've been having trouble with SmartFTP for a while now, getting "stuck" and copying files over and over and over and...
I worked with it today and it appears the files that do this are all Olympus ORF (RAW) files.  Sony Raw and JPG files don't seem to have a problem.  This is a new problem, but I'm using the same computer, so I believe there has been some change to the site I am uploading to.  On the other hand, although I've had the Olympus for a while, I used to take primarily JPG files rather than RAW with it.
I'm using Version 4.  I've tried a couple of things including disabling transfer integrity in the favorite file for this destination, but it's still copying over and over.  I should say, sometimes it succeeds.  But if I queue up a lot of files and go to bed, in the morning I'll find it stuck on two files (my limit for this process is 2).
This is a snippet from a log file.  You can see the file 20160114@145350.ORF repeating.  I don't know if there is information in the next line or not.
NOOP
[2016-01-21T17:36:17] 200 OK
[2016-01-21T17:36:41] SIZE 20160114@145350.ORF
[2016-01-21T17:36:41] 213 110483
[2016-01-21T17:36:41] MDTM 20160114@145350.ORF
[2016-01-21T17:36:42] 213 20160114205350
[2016-01-21T17:37:12] NOOP
[2016-01-21T17:37:12] 200 OK
[2016-01-21T17:37:43] SIZE 20160114@145350.ORF
[2016-01-21T17:37:43] 213 110483
[2016-01-21T17:37:43] MDTM 20160114@145350.ORF
[2016-01-21T17:37:43] 213 20160114205350
[2016-01-21T17:38:14] NOOP
[2016-01-21T17:38:14] 200 OK
I can copy .ORF files other ways, for example, using freecommander, which is free...  I like the features of SmartFTP but I don't want to spend money upgrading when I can get this done using other tools.  This is very frustrating because I've used SmartFTP for many years, through two versions.
Thanks for any suggestions for gettintg this working!
  Judy
Re: Olympus ORF files not transferring
Post by mb » Fri Jan 22, 2016 8:13 am
menu: File - Help - Request Support
