MSI Deployment with SCCM
Christian Dorsch
Post by Christian Dorsch » Fri Jun 12, 2015 8:45 am
Hi @all,
how can i deploy the MSI with right licence key with SCCM? Thanks
Re: MSI Deployment with SCCM
Post by mb » Fri Jun 12, 2015 2:09 pm
Create a registry .reg file with the serial. See
Automatic per-machine activation
https://www.smartftp.com/support/kb/adv ... f2614.html
Then push the registry file:
regedit.exe /s "%~dp0smartftp.reg"
Christian Dorsch
Post by Christian Dorsch » Tue Jun 16, 2015 6:36 am
thank you for your answer. must i create this entry? I cannot find SmartFTP under HKEY_LOCAL_MACHINE...
Last edited by Christian Dorsch on Tue Jun 16, 2015 6:36 am, edited 1 time in total.
Post by mb » Tue Jun 16, 2015 7:22 am
Yes it must be created. But if SmartFTP is already activated you can find the same value in the HKCU branch. So I recommend that you export the existing registry key from HKCU and then change the .reg file if needed.
Christian Dorsch
Post by Christian Dorsch » Fri Jun 26, 2015 7:35 am
<blockquote class="ipsBlockquote">
it doesn´t work. I have the some regkey with serial in HCLM, but the Software says "not activated.:"  Did you have any idea?
</blockquote>
Post by mb » Fri Jun 26, 2015 7:38 am
Please contact support: menu: File - Help - Request Support
