For example, I dragged a folder called "ctools" from the local window to the remote window and the files were added to the transfer queue, and then all of the files in the queue fail to upload. Here's the log from the first file in the list, which should have ended up in code/sites/all/modules/contrib/ctools ... but it fails becuase ctools/ doesn't exist yet:
[16:52:14] Operation Begin
[16:52:14] Resolving path "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib/ctools".
[16:52:14] Path successfully resolved to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib/ctools".
[16:52:14] Getting properties (Date modified, Size) of "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib/ctools/API.txt"
[16:52:14] Getting attributes of "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib/ctools/API.txt".
[16:52:14] 2 No such file or directory
[16:52:14] Uploading file to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib/ctools/API.txt".
[16:52:14] StartPosition=0, EndPosition=0.
[16:52:14] Transfer failed.
[16:52:14] Operation End
If I manually create ctools/, the transfer queue will upload things fine ... until the queue reaches files in a subdirectory of ctools/, such as ctools/css/button.css — again, because SmartFTP doesn't create the css/ directory, the file transfer fails.
I'm not convinced this is a server configuration issue because I was able to upload the entire ctools/ folder using FileZilla by doing the same kind of drag-and-drop action from local to remote. On the other hand, this is the only time I've ever seen SmartFTP have this problem uploading files to a server using SFTP.
Here's relevant system info:
Name : Microsoft® Windows Vista™ Home Premium
Version : 6.0.6002 Service Pack 2
CPU Speed : 2210 MHz
Architecture : x86
Total Memory : 3069 MB
Free Memory : 827 MB
UserName : [redacted]
Machine Id : [redacted]
Version : 5.0.1364.0
Time Stamp : 2015-04-15 05:40:24
License Id : [redacted]
Maintenance : 2016-11-20T00:00:00
Days in use : 2471
en-US
[16:49:11] SmartFTP v5.0.1364.0
[16:49:11] Resolving host name "appserver.dev.fbed5b95-fb7c-4d5e-a7be-030baf7c87a6.drush.in"
[16:49:11] Connecting to 23.253.170.215 Port: 2222
[16:49:11] Connected to appserver.dev.fbed5b95-fb7c-4d5e-a7be-030baf7c87a6.drush.in.
[16:49:11] SSH protocol version reply. Client Id: SSH-2.0-SmartFTP
[16:49:12] SSH-2.0-Twisted
[16:49:12] Starting SSH session. Remote Id: "SSH-2.0-Twisted"
[16:49:12] Server Algorithm Suite
Key Exchange: diffie-hellman-group1-sha1
Server Host Key: ssh-rsa
Client to Server Encryption: aes256-ctr,aes256-cbc,aes192-ctr,aes192-cbc,aes128-ctr,aes128-cbc,cast128-ctr,cast128-cbc,blowfish-ctr,blowfish-cbc,3des-ctr,3des-cbc
Server to Client Encryption: aes256-ctr,aes256-cbc,aes192-ctr,aes192-cbc,aes128-ctr,aes128-cbc,cast128-ctr,cast128-cbc,blowfish-ctr,blowfish-cbc,3des-ctr,3des-cbc
Client to Server HMAC: hmac-sha1,hmac-md5
Server to Client HMAC: hmac-sha1,hmac-md5
Client to Server Compression: none,zlib
Server to Client Compression: none,zlib
[16:49:12] Selected Algorithm Suite
Client to Server Compression: zlib
Server to Client Compression: zlib
[16:49:12] Client Algorithm Suite
Key Exchange: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,rsa1024-sha1
Server Host Key: ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,x509v3-sign-rsa-sha1,x509v3-sign-dss-sha1,ssh-rsa,ssh-dss
Client to Server Encryption: aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes256-ctr,aes256-cbc,rijndael256-cbc,rijndael-cbc@lysator.liu.se,aes192-ctr,aes128-ctr,3des-cbc,blowfish-cbc,cast128-cbc,aes128-cbc,rijndael128-cbc,aes192-cbc,rijndael192-cbc
Server to Client Encryption: aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes256-ctr,aes256-cbc,rijndael256-cbc,rijndael-cbc@lysator.liu.se,aes192-ctr,aes128-ctr,3des-cbc,blowfish-cbc,cast128-cbc,aes128-cbc,rijndael128-cbc,aes192-cbc,rijndael192-cbc
Client to Server HMAC: hmac-sha2-512,hmac-sha2-256,hmac-sha1,hmac-md5
Server to Client HMAC: hmac-sha2-512,hmac-sha2-256,hmac-sha1,hmac-md5
Client to Server Compression: zlib@openssh.com,zlib,none
Server to Client Compression: zlib@openssh.com,zlib,none
[16:49:12] Key Exchange Algorithm: diffie-hellman-group1-sha1
[16:49:13] Server "ssh-rsa" host key fingerprint: B5:EA:23:EB:7B:7B:0D:17:C7:13:47:92:EA:70:C1:B5
[16:49:13] Key exchange completed.
[16:49:13] Requesting service "ssh-userauth".
[16:49:13] RTT: 96.761 ms
[16:49:13] Authentication request. Method: none
[16:49:13] Server supported authentications: password,publickey
[16:49:13] Authentication request. Method: password
[16:49:13] User authentication successful.
[16:49:13] SSH session established.
[16:49:13] Opening channel 0.
[16:49:13] Channel successfully opened (Local=0, Remote=0).
[16:49:13] Requesting subystem "sftp" (Local=0, Remote=0).
[16:49:13] Sending FXP initialization. Protocol version=6.
[16:49:13] SFTP protocol version 3
[16:49:13] Resolving path ".".
[16:49:13] Path successfully resolved to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0".
[16:49:13] Resolving path "/srv/bindings/7168c07ee21e474d877da90805e1b0a0".
[16:49:13] Reading directory "/srv/bindings/7168c07ee21e474d877da90805e1b0a0".
[16:49:13] 3145 bytes transferred. (43.8 KB/s) (70 ms)
[16:49:13] Closing file handle.
[16:49:13] Directory listing complete.
[16:49:13] Getting attributes of "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/php".
[16:49:13] Attributes successfully obtained.
[16:49:13] Getting attributes of "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/drush".
[16:49:15] Resolving path "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code".
[16:49:15] Path successfully resolved to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code".
[16:49:15] Reading directory "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code".
[16:49:15] 3399 bytes transferred. (55.3 KB/s) (60 ms)
[16:49:15] Closing file handle.
[16:49:15] Directory listing complete.
[16:49:43] Resolving path "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites".
[16:49:43] Path successfully resolved to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites".
[16:49:43] Reading directory "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites".
[16:49:43] 467 bytes transferred. (8.60 KB/s) (53 ms)
[16:49:43] Closing file handle.
[16:49:43] Directory listing complete.
[16:49:43] Resolving path "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all".
[16:49:43] Path successfully resolved to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all".
[16:49:43] Reading directory "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all".
[16:49:43] 227 bytes transferred. (4.18 KB/s) (53 ms)
[16:51:11] Resolving path "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules".
[16:51:11] Path successfully resolved to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules".
[16:51:11] Reading directory "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules".
[16:51:11] 455 bytes transferred. (5.62 KB/s) (79 ms)
[16:51:11] Closing file handle.
[16:51:11] Directory listing complete.
[16:51:13] Resolving path "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib".
[16:51:13] Path successfully resolved to "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib".
[16:51:13] Reading directory "/srv/bindings/7168c07ee21e474d877da90805e1b0a0/code/sites/all/modules/contrib".
[16:51:13] 221 bytes transferred. (4.23 KB/s) (51 ms)
[16:51:13] Closing file handle.
[16:51:13] Directory listing complete.
[16:51:38] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[16:52:14] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[17:01:13] Server closed connection
