Special Character hang up in transfer
jebvixxen
Post by jebvixxen » Tue Mar 03, 2015 4:19 pm
this is what I get when I try to transfer file
[16:14:04] Operation begin
[16:14:04] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:14:04] MLST Jos Manuel Ruiz1406128899.fdf
[16:14:04] 550 Can't check for file existence
[16:14:04] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:14:04] TYPE I
[16:14:04] 200 TYPE is now 8-bit binary
[16:14:04] PASV
[16:14:04] 227 Entering Passive Mode (97,74,217,14,198,45)
[16:14:04] Opening data connection to 97.74.217.14 Port: 50733
[16:14:04] RETR Jos Manuel Ruiz1406128899.fdf
[16:14:04] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:14:04] Operation end
[16:14:04] Error 0x80043106
[16:14:35] Operation begin
[16:14:35] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:14:35] MLST Jos Manuel Ruiz1406128899.fdf
[16:14:35] 550 Can't check for file existence
[16:14:35] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:14:35] Getting properties (Size) of "C:\Users\EBrown\Documents\Jos Manuel Ruiz1406128899.fdf"
[16:14:35] PASV
[16:14:35] 227 Entering Passive Mode (97,74,217,14,197,86)
[16:14:35] Opening data connection to 97.74.217.14 Port: 50518
[16:14:35] RETR Jos Manuel Ruiz1406128899.fdf
[16:14:35] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:14:35] Operation end
[16:14:35] Error 0x80043106
[16:15:05] Operation begin
[16:15:05] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:15:05] MLST Jos Manuel Ruiz1406128899.fdf
[16:15:05] 550 Can't check for file existence
[16:15:05] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:15:05] Getting properties (Size) of "C:\Users\EBrown\Documents\Jos Manuel Ruiz1406128899.fdf"
[16:15:05] PASV
[16:15:05] 227 Entering Passive Mode (97,74,217,14,198,222)
[16:15:05] Opening data connection to 97.74.217.14 Port: 50910
[16:15:05] RETR Jos Manuel Ruiz1406128899.fdf
[16:15:05] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:15:05] Operation end
[16:15:05] Error 0x80043106
[16:15:36] Operation begin
[16:15:36] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:15:36] MLST Jos Manuel Ruiz1406128899.fdf
[16:15:36] 550 Can't check for file existence
[16:15:36] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:15:36] Getting properties (Size) of "C:\Users\EBrown\Documents\Jos Manuel Ruiz1406128899.fdf"
[16:15:36] PASV
[16:15:36] 227 Entering Passive Mode (97,74,217,14,198,192)
[16:15:36] Opening data connection to 97.74.217.14 Port: 50880
[16:15:36] RETR Jos Manuel Ruiz1406128899.fdf
[16:15:36] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:15:36] Operation end
[16:15:36] Error 0x80043106
[16:16:06] Operation begin
[16:16:06] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:16:06] MLST Jos Manuel Ruiz1406128899.fdf
[16:16:06] 550 Can't check for file existence
[16:16:06] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:16:06] Getting properties (Size) of "C:\Users\EBrown\Documents\Jos Manuel Ruiz1406128899.fdf"
[16:16:06] PASV
[16:16:06] 227 Entering Passive Mode (97,74,217,14,196,91)
[16:16:06] Opening data connection to 97.74.217.14 Port: 50267
[16:16:06] RETR Jos Manuel Ruiz1406128899.fdf
[16:16:06] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:16:06] Operation end
[16:16:06] Error 0x80043106
[16:16:36] Operation begin
[16:16:36] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:16:36] MLST Jos Manuel Ruiz1406128899.fdf
[16:16:36] 550 Can't check for file existence
[16:16:36] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:16:36] Getting properties (Size) of "C:\Users\EBrown\Documents\Jos Manuel Ruiz1406128899.fdf"
[16:16:36] PASV
[16:16:36] 227 Entering Passive Mode (97,74,217,14,198,123)
[16:16:36] Opening data connection to 97.74.217.14 Port: 50811
[16:16:36] RETR Jos Manuel Ruiz1406128899.fdf
[16:16:36] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:16:36] Operation end
[16:16:36] Error 0x80043106
[16:17:07] Operation begin
[16:17:07] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:17:07] MLST Jos Manuel Ruiz1406128899.fdf
[16:17:07] 550 Can't check for file existence
[16:17:07] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:17:07] Getting properties (Size) of "C:\Users\EBrown\Documents\Jos Manuel Ruiz1406128899.fdf"
[16:17:07] PASV
[16:17:07] 227 Entering Passive Mode (97,74,217,14,198,255)
[16:17:07] Opening data connection to 97.74.217.14 Port: 50943
[16:17:07] RETR Jos Manuel Ruiz1406128899.fdf
[16:17:07] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:17:07] Operation end
[16:17:07] Error 0x80043106
[16:17:37] Operation begin
[16:17:37] Getting properties (Size, Date modified) of "/1/Jos Manuel Ruiz1406128899.fdf"
[16:17:37] MLST Jos Manuel Ruiz1406128899.fdf
[16:17:37] 550 Can't check for file existence
[16:17:37] Unable to obtain properties of file "/1/Jos Manuel Ruiz1406128899.fdf". Error=0x80070002
[16:17:37] Getting properties (Size) of "C:\Users\EBrown\Documents\Jos Manuel Ruiz1406128899.fdf"
[16:17:37] PASV
[16:17:37] 227 Entering Passive Mode (97,74,217,14,196,12)
[16:17:37] Opening data connection to 97.74.217.14 Port: 50188
[16:17:37] RETR Jos Manuel Ruiz1406128899.fdf
[16:17:37] 550 Can't open Jos Manuel Ruiz1406128899.fdf: No such file or directory
[16:17:37] Operation end
[16:17:37] Error 0x80043106
Re: Special Character hang up in transfer
Post by mb » Tue Mar 03, 2015 4:26 pm
menu: File - Help - Request Support
