Import all FTP Accounts from Cpanel
wopibr
Post by wopibr » Wed Feb 25, 2015 11:32 am
I was trying to use the CPanel import acounts function, but always returns me "Connection Failed."
If i use the same credentials to the reseller of cpanel, i can login to via FTP, but not to import all accounts as your KB
https://www.smartftp.com/support/kb/how- ... f2622.html
Is there any log to check, permissions or config to enable or change in cpanel, windows, smartftp?
I'm really looking forward to this function.
Re: Import all FTP Accounts from Cpanel
Post by mb » Wed Feb 25, 2015 1:26 pm
Could you send url you are using by email to support?
wopibr
Post by wopibr » Wed Feb 25, 2015 9:57 pm
What is the support e-mail?
I'm using the latest trial version from downloads.
Post by mb » Fri Feb 27, 2015 5:10 am
The cPanel importer has been updated in the latest version:
