auto rename
bergschaf
auto rename
Post by bergschaf » Fri Feb 06, 2015 8:20 pm
Dear Helpers,
i created a rename rule file*.jpg should be called only file.jpg.
If I move a file file1q2412.jpg from a local folder to the server folder Test, it will be automatically renamed to file.jpg.
On the otherhand, if my ipcam sends to file2015.jpg to the server folder Test, it does not rename it.
What do I have to change that it works?
Thanks for the help
Re: auto rename
Post by mb » Mon Feb 16, 2015 11:45 am
Please contact support: menu: File - Help - Request Support
