Server Busy
geohei
Server Busy
Post by geohei » Sun Jan 18, 2015 11:37 am
Hi.
When I delete a big file on a slow Unix server, I get the "Server Busy" message.
Selecting "Retry" works after the file is actually deleted.
It seems (?!) to be when SmartFTP doesn't get  feedback from the server that a file deleted.
How can I change this timeout or avoid this message?
This didn't help:
https://www.smartftp.com/forums/index.p ... entry62533
https://www.smartftp.com/support/kb/thi ... f2589.html
Re: Server Busy
Post by mb » Sun Jan 18, 2015 1:27 pm
You cannot change the timeout. But you can change the way the file is deleted:
- menu: File - Settings
- Go to the General - Navigation page
- Set the Delete option to Queue
geohei
Re: Server Busy
Post by geohei » Mon Jan 19, 2015 6:12 am
Uuuhhh ... works!
Tricky ... wouldn't have found out on my own!
Thanks!
