SetUnixAttributes sending wrong value
#1 carl
Posted 14 November 2005 - 05:30 PM
I'm using the SmartFTP library with C++. I found that the SetUnixAttributes() method does not send the correct value to the server.
For example:
The server log shows:
[20051114 17:27:28] SITE CHMOD 2FF myfile.txt
It should be SITE CHMOD 767 myfile.txt
#2 eyebex
  • Licensed User
  • 1860 posts
Posted 14 November 2005 - 05:52 PM
No, this is no bug. The Unix-like "767" is on octal format (which is normally preceeded by "0", a zero), but the paramater "767" is interpreted as a decimal number. Fix: Use "0x767" or "767h" (depending on the script language you use) as a parameter to specify a hexadecimal number. For digits < 8 these are the same as octal.
