ftpDataTransferTypeImage script command
9 replies to this topic
#1 Hamilton345
Hamilton345
  • 10 posts
Posted 01 November 2005 - 05:06 PM
Does anyone know how to change this to use ASCII instead of binary. I have tried ftpDataTransferTypeASCII but it still defaults to binary. I am uploading a file from a Windows box to Unix.
Scott
  • 11960 posts
Posted 03 November 2005 - 08:09 PM
Hello Scott ..
Is this a SmartFTP FTP Library related question?
#3 Hamilton345
Hamilton345
  • 10 posts
Posted 03 November 2005 - 08:20 PM
yes
  • 11960 posts
Posted 03 November 2005 - 10:17 PM
ftp.DataTransferType = ftpDataTransferTypeASCII;
or
ftp.DataTransferType = 1;
where ftp is the FTPConnection object.
#5 Hamilton345
Hamilton345
  • 10 posts
Posted 04 November 2005 - 04:36 PM
I tried that but it still doesn't work. I am using the trial version, could this be the problem.
  • 11960 posts
Posted 04 November 2005 - 05:50 PM
Please post your code and the transfer logs. It has nothing to do with the trial version.
#7 Hamilton345
Hamilton345
  • 10 posts
Posted 04 November 2005 - 07:57 PM
I used the samples provided with the SmartFTP FTP library download and made modifications to them. The files I used are
Uploadfile.wsf
Favorite - smartftp.com.vbs (ScriptA)
Shared.vbs (ScriptB)
I appreciate your help.
<?xml version="1.0"?>
<package>
<job>
<reference object="sfFTPLib.FTPConnectionSTA"/>
<script language="VBScript" src="ScriptA.vbs"/>
<script language="VBScript" src="ScriptB.vbs"/>
<script language="VBScript">
<![CDATA[
'// UploadFile v1.0 (8. November 2004)
'// Purpose:
'// Uploads multiple files from your local computer to the remote server.
'// Returns:
'// 0 on success
'// 1 on error (connect)
'// 2 on download
'// Limitations:
'// No retries
'// No option to set file time (MDTM) of uploaded files
'// Copyright © 2004 by SmartFTP.com
Option Explicit
'Globals
Dim g_objFTP
Dim g_objFS
Dim nReturn ' script return value
'// Application Settings
' Global const
Const g_cDebug = 1 ' debug level. 0=disable, 1=enable. see Trace() in shared.vbs
' Local const
Const cResume = true ' true=resume, false=overwrite
' File List (index 0 = remote file, index 1 = local file)
Dim arrFiles(1, 1) ' 2 files
' FIXME: . only for testing purpose.
arrFiles(0, 0) = "test.txt"
arrFiles(0, 1) = "/aa12345/test.txt"
'arrFiles(1, 0) = ".test.txt" ' . = current working directory
'arrFiles(1 ,1) = "/SmartFTP/License.txt"
' Note: see below for FTP settings
'// Entry
nReturn = 0
Set g_objFTP = CreateObject("sfFTPLib.FTPConnectionSTA")
'// FTP Settings
Call InitFTPSettings(g_objFTP)
' logging
g_objFTP.LogFile = ".LogUploadFile.log"
'// Operation
Set g_objFS = CreateObject("Scripting.FileSystemObject")
' Connect
Dim result
result = g_objFTP.Connect()
If result = ftpErrorSuccess Then
' Call Trace("Connected")
Dim bError : bError = false
Dim i
For i=0 To ubound(arrFiles)
Dim bRet
bRet = UploadFile(g_objFTP, arrFiles(i,0), arrFiles(i,1), cResume)
If Not bRet Then
' Ignore and continue
bError = true
End If
Next
' if an error occured set script return value
If bError Then
nReturn = 2
End If
' Disconnect
result = g_objFTP.Disconnect()
' Call Trace("Disconnected.")
Else
If result = ftpErrorLicense Then
Call Trace("Please acquire a license from http://www.smartftp.com")
Else
Call Trace("Connection failed. Error = " & result)
End If
nReturn = 1
End If
' Cleanup
Set g_objFTP = Nothing
Set g_objFS = Nothing
WScript.Quit(nReturn)
</script>
</job>
</package>
ScriptA
'// FTP Settings
Sub InitFTPSettings(objFTP)
objFTP.Host = "host.com"
objFTP.Username = "username"
objFTP.Password = "password"
objFTP.HidePassword = true
objFTP.Port = 12345
objFTP.Protocol = ftpProtocolSSLExplicit ' ftpProtocolSSLExplicit for SSL Explicit
objFTP.Passive = true
objFTP.MLST = true ' Use MLST if available
objFTP.DataTransferMode = ftpDataTransferModeStream ' ftpTransferModeZ for zlib compression
objFTP.DataTransferType = 1 ' ASCII. ASCII mode is not recommended.
objFTP.DataProtection = ftpDataProtectionPrivate ' Private (Secure), Clear (Unsecure)
' Proxy Settings (SOCKS, HTTP)
objFTP.ProxyType = ftpProxyTypeNone
objFTP.ProxyHost = ""
objFTP.ProxyPort = 8080
objFTP.ProxyUsername = ""
objFTP.ProxyPassword = ""
objFTP.ProxyAuthentication = false
' FTP Proxy Settings
objFTP.FTPProxyType = ftpFTPProxyTypeNone
objFTP.FTPProxyHost = ""
objFTP.FTPProxyPort = 12345
objFTP.FTPProxyUsername = ""
objFTP.FTPProxyPassword = ""
objFTP.FTPProxyAuthentication = false
objFTP.Client = "Host.com Script"
' Performance
'objFTP.FileBufferSize = 32768
'objFTP.SendBufferSize = 2048
'objFTP.ReceiveBufferSize = 8192
End Sub
ScriptB
'// Shared.vbs v1.1 (5. July 2005)
'// Purpose:
'// Contains helper functions for the samples.
'// External dependencies:
'// g_objFS : Scripting.FileSystemObject object
'// g_cDebug : debug flag (1=enable, 2=disable)
'// Copyright © 2004 - 2005 by SmartFTP.com
Option Explicit
'// Trace
'// enable/disable with g_cDebug flag
Sub Trace(strMsg)
If g_cDebug = 1 Then
WScript.Echo strMsg & vbCrLf
End If
End Sub
'// DownloadDirectory
'// strRemoteFolder: Path to remote folder e.g. /ce262700
'// strLocalFolder : Path to local folder e.g. ce262700
'// Returns: true on sucess, false otherwise
Function DownloadDirectory(objFTP, strRemoteFolder, strLocalFolder, bResume)
Dim bRet : bRet = false
If LocalCreateDirectory(strLocalFolder) Then
' ChangeDirectory
If ChangeDirectory(objFTP, strRemoteFolder) Then
bRet = true
' Read Directory
result = g_objFTP.ReadDirectory()
Dim objDirectory
Set objDirectory = objFTP.Directory
Dim FTPFile
For Each FTPFile In objDirectory
If FTPFile.Name <> "." And FTPFile.Name <> ".." Then
If FTPFile.Type = ftpItemTypeFile Then
Dim strRemoteFile : strRemoteFile = UnixBuildPath(strRemoteFolder, FTPFile.Name)
Dim strLocalFile : strLocalFile = g_objFS.BuildPath(strLocalFolder, FTPFile.Name)
bRet = DownloadFile(objFTP, strRemoteFile, strLocalFile, bResume)
If Not bRet Then
Call Trace("Failed to download " & strRemoteFile & ".")
' ignore error. continue
bRet = true
End If
ElseIf FTPFile.Type = ftpItemTypeFolder Then
Dim strNewRemoteFolder : strNewRemoteFolder = UnixBuildPath(strRemoteFolder, FTPFile.Name)
Dim strNewLocalFolder : strNewLocalFolder = g_objFS.BuildPath(strLocalFolder, FTPFile.Name)
bRet= DownloadDirectory(objFTP, strNewRemoteFolder, strNewLocalFolder, bResume)
If Not bRet Then
Call Trace("Failed to download " & strNewRemoteFolder & ".")
bRet = true
End If
ElseIf FTPFile.Type = ftpItemTypeLink Then
' we ignore links
End If
End If
Next
Set objDirectory = Nothing
Else
Call Trace("Read directory failed. Error = " & result)
End If
Else
Call Trace("Change directory to " & strRemoteFolder & " failed.")
End If
End If
' set return value
DownloadDirectory = bRet
End Function
'// DownloadFile
'// strRemoteFile : Path to remote file e.g. /ce262700/
'// strLocalFile : Path to local folder e.g. ce262700History.txt
Function DownloadFile(objFTP, strRemoteFile, strLocalFile, bResume)
Dim strLocalFolder: strLocalFolder = PathRemoveFileSpec(strLocalFile)
Dim strFile : strFile = UnixPathGetLast(strRemoteFile)
Dim strPath : strPath = UnixPathRemoveFileSpec(strRemoteFile)
If ChangeDirectory(objFTP, strPath) Then
Dim nRestart : nRestart = 0 ' overwrite by default
Dim bSkip : bSkip = false ' don't skip, unless equal size
If bResume Then
' Get Remote File Size
result = objFTP.GetFileSize(strFile)
Dim nRemoteFileSize : nRemoteFileSize = objFTP.LastFileSizeLo
If nRemoteFileSize > 0 Then
' Get Local File Size
Dim nLocalFileSize : nLocalFileSize = 0
On Error Resume Next
Dim f
Set f = g_objFS.GetFile(strLocalFile)
If Err.Number = 0 Then
nLocalFileSize = f.Size
Set f = Nothing
End If
On Error GoTo 0
If nLocalFileSize = nRemoteFileSize Then
bSkip = true
Call Trace("Skipping file """ & strRemoteFile & """. Reason equal size.")
ElseIf nLocalFileSize < nRemoteFileSize Then
' Only resume if local size is smaller than remote size
nRestart = nLocalFileSize
End If
End If
End If
End If
If bSkip = false Then
' DownloadFile
result = objFTP.DownloadFile(strFile, strLocalFile, nRestart, 0)
bRet = true
Else
Call Trace("DownloadFile of " & strFile & " failed. Error = " & result)
bRet = false
End If
Else
bRet = true
End If
Else
Call Trace("Change directory to " & strPath & " failed.")
End If
End If
DownloadFile = bRet
End Function
'// UploadFile
'// strLocalFile : Path to local file e.g. ce262700
'// Note: Function will fail if remote directory doesn't exist
Function UploadFile(objFTP, strLocalFile, strRemoteFile, bResume)
Dim bFileExists : bFileExists = false ' pessimistic assumption
Dim f
bFileExists = true
Set f = Nothing
' Else
' Call Trace("Local file '" & strLocalFile & "' doesn't exist.")
End If
On Error GoTo 0
If bFileExists Then
' Change remote directory
If bResume Then
bSkip = true
ElseIf nLocalFileSize > nRemoteFileSize Then
' Only resume if local size is greater than remote size
nRestart = nRemoteFileSize
End If
End If
End If
' UploadFile
result = objFTP.UploadFile(strLocalFile, strFile, nRestart, 0)
bRet = true
Else
Call Trace("UploadFile of " & strFile & " failed. Error = " & result)
bRet = false
End If
Else
bRet = true
End If
Else
End if
End If
UploadFile = bRet
End Function
'// FXPFile
'// strFileSource : Path to source file e.g. /ce262700/
'// strFileDestination : Path to destination file e.g. /ce262700/
Function FXPFile(objFTPSource, objFTPDestination, strFileSource, strFileDestination, bResume)
' Change Directory
Dim strFilenameSource : strFilenameSource = UnixPathGetLast(strFileSource)
Dim strPathSource : strPathSource = UnixPathRemoveFileSpec(strFileSource)
Dim strFilenameDestination : strFilenameDestination= UnixPathGetLast(strFileDestination)
Dim strPathDestination : strPathDestination = UnixPathRemoveFileSpec(strFileDestination)
If ChangeDirectory(objFTPSource, strPathSource) And ChangeDirectory(objFTPDestination, strPathDestination) Then
If bResume Then
' Get Source File Size
result = objFTPSource.GetFileSize(strFilenameSource)
Dim nFileSizeSource : nFileSizeSource = objFTPSource.LastFileSizeLo
' Get Destination File Size
result = objFTPDestination.GetFileSize(strFilenameDestination)
Dim nFileSizeDestination : nFileSizeDestination = objFTPDestination.LastFileSizeLo
If nFileSizeSource = nFileSizeDestination Then
bSkip = true
ElseIf nFileSizeSource > nFileSizeDestination Then
nRestart = nFileSizeSource
End If
End If
End If
End If
Dim objFTPFXP
Set objFTPFXP = CreateObject("sfFTPLib.FTPFXP")
objFTPFXP.Source = objFTPSource
objFTPFXP.Destination = objFTPDestination
' FXPFile
result = objFTPFXP.FXPFile(strFilenameSource, strFilenameDestination, nRestart, 0)
bRet = true
Else
Call Trace("FXPFile of " & strFilenameSource & " failed. Error = " & result)
bRet = false
End If
Else
Call Trace("Skipping file """ & strFilenameSource & """. Reason equal size.")
bRet = true
End If
Else
Call Trace("Change directory to " & strPathSource & " failed.")
End If
FXPFile = bRet
End Function
'// UploadDirectory
Function UploadDirectory(objFTP, strLocalFolder, strRemoteFolder, bResume)
' Create remote directory first
If MakeDirectory(objFTP, strRemoteFolder) Then
' ChangeDirectory
bRet = true
' Read Local Directory
Dim bGetFolder : bGetFolder = false
Dim objFolder
Set objFolder = g_objFS.GetFolder(strLocalFolder)
bGetFolder = true
Else
Call Trace("GetFolder(""" & strLocalFolder & """) failed." & " Error = " & Err.Number)
End If
On Error GoTo 0
If bGetFolder Then
' Files
Dim objFileList
Set objFileList = objFolder.Files
Dim File
For Each File In objFileList
If File.Name <> "." And File.Name <> ".." Then
Dim strRemoteFile : strRemoteFile = UnixBuildPath(strRemoteFolder, File.Name)
Dim strLocalFile : strLocalFile = g_objFS.BuildPath(strLocalFolder, File.Name)
bRet = UploadFile(objFTP, strLocalFile, strRemoteFile, bResume)
If Not bRet Then
Call Trace("Failed to upload " & strRemoteFile & ".")
bRet = true
End If
End If
Next
Set objFileList = Nothing
' Folders
Dim objFolderList
Set objFolderList = objFolder.SubFolders
Dim Folder
For Each Folder In objFolderList
If Folder.Name <> "." And Folder.Name <> ".." Then
Dim strNewRemoteFolder : strNewRemoteFolder = UnixBuildPath(strRemoteFolder, Folder.Name)
Dim strNewLocalFolder : strNewLocalFolder = g_objFS.BuildPath(strLocalFolder, Folder.Name)
bRet= UploadDirectory(objFTP, strNewLocalFolder, strNewRemoteFolder, bResume)
If Not bRet Then
Call Trace("Failed to upload " & strNewRemoteFolder & ".")
bRet = true
End If
End If
Next
Set objFolderList = Nothing
Set objFolder = Nothing
End If
Else
End If
End If
' set return value
UploadDirectory = bRet
End Function
'// ChangeDirectory
'// objFTP : FTPConnection object
'// strPath : path to remote directory
'// Changes remote working directory only if server working path is not equal to strPath
'// Returns: true on success, false otherwise
Function ChangeDirectory(objFTP, strPath)
If strPath = objFTP.WorkingDirectory Then
bRet = true
Else
' ChangeDirectory
result = objFTP.ChangeDirectory(strPath)
bRet = true
End If
End If
ChangeDirectory = bRet
End Function
'// MakeDirectory
'// Makes remote directory if directory doesn't exist yet
Function MakeDirectory(objFTP, strPath)
' does remote directory exist?
bRet = true
Else
' change to parent and make dir
Dim strLeft : strLeft = UnixPathRemoveLast(strPath)
'Call Trace("MakeDirectory(): Parent = " & strLeft)
If ChangeDirectory(objFTP, strLeft) Then
Dim strFile : strFile = UnixPathGetLast(strPath)
' MakeDirectory
result = objFTP.MakeDirectory(strFile)
bRet = true
Else
Call Trace("Failed to make directoryto """ & strPath & """. Error = " & result)
End If
End If
End If
MakeDirectory = bRet
End Function
'// LocalCreateDirectory
'// Purpose:
'// Recursively creates a local directory.
'// Input:
'// strFolder: Path to folder
'// fals otherwise
Function LocalCreateDirectory(strFolder)
Dim bRet : bRet = true
Dim nLastPos : nLastPos = 1
Dim nPos
Do
Dim strLeft
nPos = InStr(nLastPos, strFolder, "", 1)
If nPos = 0 Then
strLeft = strFolder
Else
strLeft = Left(strFolder, nPos - 1)
End If
If Len(strLeft) > 0 Then
' no drive
If Right(strLeft, 1) <> ":" Then
' Local folder check
Dim bFolderExists : bFolderExists = g_objFS.FolderExists(strLeft)
If Not bFolderExists Then
' Create local folder
Dim f
Set f = g_objFS.CreateFolder(strLeft)
bFolderExists = true
Else
Call Trace("Failed to create local folder" & strLeft & ". Error = " & Err.Number)
bRet = false
End If
On Error GoTo 0
If Not bRet Then
Exit Do
End If
End If
End If
End If
If nPos = Len(strFolder) Then
Exit Do
End If
nLastPos = nPos + 1
Loop Until nPos = 0
LocalCreateDirectory = bRet
End Function
'// UnixBuildPath
'// strBase : Base path
'// strAppend : Path to append
'// Returns: Full path
'// Note: Works for UNIX paths only!!!
Function UnixBuildPath(strBase, strAppend)
Dim strFull
strFull = strBase
If Right(strFull, 1) <> "/" Then
strFull = strFull & "/"
End If
strFull = strFull & strAppend
UnixBuildPath = strFull
End Function
'// UnixPathGetLast
'// strPath : path
'// Returns: last part of path
Function UnixPathGetLast(strPath)
Dim nPos : nPos = InStrRev(strPath, "/")
Dim str : str = Mid(strPath, nPos + 1)
UnixPathGetLast = str
End Function
'// UnixPathRemoveLast
'// strPath : path
'// Returns: path with last part removed
'// removes '/' at the end
'// Examples:
'// "/test" returns "/"
'// "/test/bla" returns "/test"
'// "/test/bla/" returns "/test"
Function UnixPathRemoveLast(strPath)
Dim str
' remove ending '/'
Dim nLen : nLen = Len(strPath)
If Right(strPath, 1) = "/" Then
str = strPath.Left(nLen - 1)
Else
str = strPath
End If
str = UnixPathRemoveFileSpec(str)
UnixPathRemoveLast = str
End Function
'// UnixPathRemoveFileSpec
'// strPath : path
'// Returns: path with filespec removed from path
'// Examples:
'// "/test/bla/" returns "/test/bla"
Function UnixPathRemoveFileSpec(strPath)
Dim str
If nPos > 0 Then
str = Left(strPath, nPos - 1)
If Len(str) = 0 Then
str = "/"
End If
Else
str = strPath
End If
UnixPathRemoveFileSpec = str
End Function
'// PathRemoveFileSpec
'// strPath : path
Function PathRemoveFileSpec(strPath)
Dim nPos : nPos = InStrRev(strPath, "")
Dim str
If nPos > 0 Then
Else
str = strPath
End If
End Function
#8 Hamilton345
Hamilton345
  • 10 posts
Posted 04 November 2005 - 08:04 PM
[20051104 19:59:47] SmartFTP FTP Library v1.5.7.2
[20051104 19:59:47] Resolving host name "host.com"
[20051104 19:59:47] Connecting to 1.1.1.1 Port: 12345
[20051104 19:59:47] Connected to host.com.
[20051104 19:59:47] 220 <<<Connect:Enterprise UNIX 2.2.00 Secure FTP>>> at FTP server ready. Time = 13:59:52
[20051104 19:59:47] AUTH TLS
[20051104 19:59:47] 234 AUTH TLS-C/TLS OK.
[20051104 19:59:47] Connected. Exchanging encryption keys...
[20051104 19:59:48] Session Cipher: 168 bit 3DES
[20051104 19:59:48] SSL encrypted session established.
[20051104 19:59:48] PBSZ 0
[20051104 19:59:48] 200 PBSZ 0 OK.
[20051104 19:59:48] USER username
[20051104 19:59:49] 331 Password required for username.
[20051104 19:59:49] PASS (hidden)
[20051104 19:59:49] 230 Connect:Enterprise UNIX login ok, access restrictions apply.
[20051104 19:59:49] SYST
[20051104 19:59:49] 215 UNIX Type: L8
[20051104 19:59:49] FEAT
[20051104 19:59:49] 500 'FEAT': command not understood.
[20051104 19:59:49] TYPE I
[20051104 19:59:49] 200 Type set to I.
[20051104 19:59:49] REST 0
[20051104 19:59:49] 550 Operation is not supported under Connect:Enterprise FTP server.
[20051104 19:59:49] PWD
[20051104 19:59:49] 257 "/aa12345" is current directory.
[20051104 19:59:49] CWD /aa12345
[20051104 19:59:49] 250 CWD command successful.
[20051104 19:59:49] SIZE test.txt
[20051104 19:59:49] PROT P
[20051104 19:59:50] 200 PROT P OK, data channel will be secured.
[20051104 19:59:50] PASV
[20051104 19:59:50] 227 Entering Passive Mode (1,1,1,1,82,8)
[20051104 19:59:50] Opening data connection to 1.1.1.1 Port: 12346
[20051104 19:59:50] STOR test.txt
[20051104 19:59:50] Connected. Exchanging encryption keys...
[20051104 19:59:50] 150 Opening BINARY mode data connection for test.txt.
[20051104 19:59:50] Session Cipher: 168 bit 3DES
[20051104 19:59:50] SSL encrypted session established.
[20051104 19:59:53] 226- Transfer complete - acknowledgment message is pending.
[20051104 19:59:54] 226- Transfer complete - acknowledgment message is pending.
[20051104 19:59:54] 21104 bytes transferred. (4.93 KB/s) (00:00:04)
[20051104 19:59:54] 226 Transfer complete (Batch Number = 98745).
[20051104 19:59:54] QUIT
[20051104 19:59:54] 221 Goodbye.
[20051104 19:59:54] Client closed the connection.
#9 mb
  • 11960 posts
Posted 06 November 2005 - 03:46 AM
Thank you. Indeed the DataTransferType property had no effect because it has been set before the Connect() call. The updated scripts now set the DataTransferType depending on the file transferred. The important thing to remember is to set the DataTransferType after the Connect() call. Preferably right before the actual data transfer.
Thank you for reporting.
#10 Hamilton345
Hamilton345
  • 10 posts
Posted 07 November 2005 - 02:10 PM
That worked. Thanks for all your help.
Scott
