LoadLicenseKeyData dosn't work correctly
7 replies to this topic
#1 uksbi
uksbi
  • 13 posts
    Bielefeld, Germany
Posted 11 August 2005 - 02:29 PM
we are using the sfFTPLib.dll in version 1.5.3.3 and testing our software
under Win98SE, WinMe, Win2KSP2, Win2KSP4, WinXPSP2 and Win2003 ...
So we have a problem under Win98 and WinME ... the following code
returns FALSE ?!?!
   strKey = " .... "
    Set objGlobal = CreateObject("sfFTPLib.Global")
    If objGlobal.LoadLicenseKeyData(strKey) = True Then
        Debug.Print "+ INFO ... SmartFTP Registrierung ... OK"
      Else
        Debug.Print "+ ERROR ... SmartFTP nicht registriert"
    End If
Under Win2K, WinXP and Win2003 returns the same program with the
same code TRUE?!
And now .. what can we do?
CU Ulf
  • 11960 posts
Posted 11 August 2005 - 03:55 PM
Hallo Ulf ...
Did you install Internet Explorer 5.x or higher on the Windows 9x system? Its a requriement for the FTP library because of the MS crypto functions.
#3 uksbi
uksbi
  • 13 posts
    Bielefeld, Germany
Posted 12 August 2005 - 06:34 AM
yes we do ...
WinME = IE 6.0.2800.1106 / Encryption 128Bit
Win98 = IE 5.00.2614.3500 / Encryption 40Bit
CU Ulf
#4 uksbi
uksbi
  • 13 posts
    Bielefeld, Germany
Posted 12 August 2005 - 09:12 AM
Hi ... its me again :-)
we do some test with the Win98-System .. installing all availible updates
for the system and updating to IE6 (same version like on Me).
But the functions does return FALSE again!
CU Ulf
#5 mb
  • 11960 posts
Posted 12 August 2005 - 10:21 AM
Are you using Windows 98 or Windows 98 SE?
I tested it on a Windows 98 SE with the latest updates and it works.
Do you use any instant messenger where I can contact you?
#6 uksbi
uksbi
  • 13 posts
    Bielefeld, Germany
Posted 12 August 2005 - 10:53 AM
Hi Mat,
You can contact me by ICQ ... removed
it is Win98 SE ..
Posted Image
CU Ulf
#7 mb
  • 11960 posts
Posted 12 August 2005 - 12:55 PM
Fixed in the latest build.
Thanks for your prompt responses :-)
#8 uksbi
uksbi
  • 13 posts
    Bielefeld, Germany
Posted 15 August 2005 - 09:52 AM
works also fine under blank Win98 with IE 5.0 and
without any windowsupdate.
CU Ulf
