Problem with Alt+Tab
2 replies to this topic
#1 sobel
sobel
  • 19 posts
Posted 14 June 2005 - 10:36 AM
Please try this:
1. from SmartFTP window, switch to any other window using Alt+Tab
2. go back to SmartFTP using either Alt+Tab or a mouse click on its icon in taskbar
3. try to highlight a remote file/folder inside the FTP window in SmartFTP
If you can reproduce this you will find that the first click won't work and you need a second mouse click.
Now try everything again except in step 1 don't use Alt+Tab but a mouse click on an icon in the taskbar. This time it will work fine.
I've noticed this problem for a couple of months now.
#2 eyebex
eyebex
  • Licensed User
  • 1860 posts
Posted 14 June 2005 - 06:09 PM
Successfully reproduced with version 1.5.988.15.
#3 mb
  • 11932 posts
Posted 17 June 2005 - 01:59 AM
Bug confirmed. It's not easy to fix. Hower it only happens if the main menu is focused prior to pressing Alt+Tab.
