SmartFTP Installation Problems
25 replies to this topic
#21 jberger
jberger
Posted 07 September 2007 - 09:34 PM
I was using Smart FTP (I don't know what version) and it said my build was about to expire, so I downloaded a newer build, using the link on the message. After downloading yesterday, I was able to use the software without a problem. Today, when I went to go use it, it says that "The source installation package for the product SmartFTP client is out of sync with the client package. Try the installation again using a valid copy of the installation package 'SmartFTP.msi'." I have tried re-downloading the software, but it doesn't help.
HELP!!
#22 mb
  • 11975 posts
Posted 07 September 2007 - 09:40 PM
Uninstall the version installed and install it again.
#23 michaeljames
michaeljames
Posted 21 September 2007 - 10:23 PM
[quote name='mb' date='Nov 11 2004, 09:39 PM' post='25747']
According to the recent poll we ran on the web site, there is a certain amount of users having problems with the official setup.
The official setup is the one available here:
We are interested to know what kind of problems you have/had installing SmartFTP.
Thank you SO much for the official setup link above. When I tried to install the program, the link I downloaded didn't work, and I got a message onscreen about windows/system32/advpack.dll which didn't make a lot of sense to me. Anyway, your link above worked a treat, and the program installed/setup instantly, and it seems to be performing just fine! <_<
Thanks again and, in return, I promise to buy the program as soon as my site generates some income! :angry:
Keep smiling!
Mike
Edited by michaeljames, 21 September 2007 - 10:24 PM.
#24 Pactum
Pactum
Posted 10 October 2007 - 12:59 AM
I licensed SmartFTP a few years ago. I downloaded and installed 2.5 yesterday. I didn't notice any warnings that I was going to lose my licensed version until I went to start up 2.5. Then I was informed that my license has expired and I'm not qualified to use 2.5. Trouble is, since the new install I can't find my earlier version - it seems to have been overwritten. Is this some sort of forced upgrade? I was satisfied with my earlier version; I really don't want to shell out money for something I don't need, although I'll likely upgrade at some point.
What am I supposed to do?
Thanks!
P.S. I'll also add that all my previous settings have been lost too.
Edited by Pactum, 10 October 2007 - 01:29 AM.
#25 Russell
Russell
Posted 01 November 2007 - 08:28 PM
I had the free version of smartFTP install and it work fine.
Then I tried to install the new release and received the following error message:
["The installed product does not match the installation sources. Until a matching source is provided
or the installed product and source are syschronized, this action cannot be performed.]
When I try to install in the same location as the previouse product, I get the
following message:
"C:\Documents and Settings\Russell\Desktop\SmartFTP Client Setup Files\SmartFTP.msi
is not a valid installation package foe the product "SmartFTP Client"
Try to find the installation package "SmartFTP.msi" in a folder from which you can install
SmartFTP Client]
Even when I try to use the older version I now get that message.
Any help is appreciated.
Russell
Problem
Setup was unable to upgrade the windows installer. Failed to load 'msi.dll'
Fix
Please install this one:
http://www.microsoft...;displaylang=en
Problem
When I try to start it, is says "could not access network location:."
I have tried uninstalling, but I can't do that either, because I get the same error. I tried downloading the NSI version, but as soon as it tries to install, I get the same message. I have no choices with the message but "retry" or "cancel". Retry does nothing, of course. If I cancel, I cancel the install or removal. What do I do??
The file 'path to SmartFTP Client Setup Files" is not a valid installation package for the product SmartFTP Client. Try to find the installation package in a folder from which you can install SmartFTP Client.
Fix
Download the Windows Installer CleanUp Tool from:
http://support.micro...kb;en-us;290301
and use the tool to remove SmartFTP from the installed applications.
Then run the SmartFTP NSI setup from:
Problem
When I try to start SmartFTP for the first time after installing, I get an error message "The SMARTFTP.EXE file is linked to missing export SHLWAPI.DLL:PathUnExpandEnvStringsW." Restarting, uninstall/reinstalling and using the repair function through Add/Remove programs have not had any effect.
Fix
Install Internet Explorer 5.x or higher and make sure the unicows.dll is in the SmartFTP application directory.
Please post a short description what isn't or wasn't working for you.
Thank you for your time.
SmartFTP.com
#26 mb
  • 11975 posts
Posted 01 November 2007 - 09:11 PM
It's more than enough to make one posting for the same problem.
