Local Browser Problem in Build 981
9 replies to this topic
#1 Kravvitz
Kravvitz
  • 15 posts
Posted 22 April 2004 - 01:49 AM
Prior to Build 981, SmartFTP remembered that I had two local browser windows opened and would reopen them every time I started the program. After I updated to Build 981 it only remembers one local browser window. I have uninstalled, reinstalled, and rebooted, but that did not solve the problem.
I looked in the registry and found that on opening, it only reads the two entries for "Local Browser 0", ignoring the two entries for "Local Browser 1".
I hope you can fix this in the next build.
  • 11935 posts
Posted 23 April 2004 - 01:07 AM
Hi ..
I cannot reproduce the problem you have reported with the latest developer build.
SmartFTP.com
#3 Kravvitz
Kravvitz
  • 15 posts
Posted 23 April 2004 - 01:37 AM
I get the problem with the dev build too. Here is the System Info (I bet this feature makes support easier.):
Microsoft Windows 98 SE
Total Memory      : 65028 KB
Free Memory       :    48 KB
Version           : 1.0.981.44
Time Stamp        : 2004-04-22 07:46:31
controls.dll      : 1.6.981.44
ftpapi.dll        : 2.0.981.44
language.dll      : 1.0.981.44
reseng.dll        : 1.3.981.44
smarthook.dll     :
unicows.dll       : 1.0.4018.0
shell32.dll       : 4.72.3612.1700
shlwapi.dll       : 6.00.2800.1400
comctl32.dll      : 5.81
riched20.dll      : 5.30.23.1200
schannel.dll      : 5.00.1878.13
Version           : 6.0.2800.1106
Winsock           : 2.2
EDIT: I should also mention that the backup utility doesn't add the extension to the filename and saves it to the program directory instead of the %WindowsDir%/Personal/. When I try to restore from it after going to the SmartFTP directory and showing all files, it doesn't appear to actually restore my settings.
EDIT 2: How can I make SmartFTP remember Recent (Local) Folders?
  • 11935 posts
Posted 23 April 2004 - 03:22 AM
Does the selected/openend directory in the Localbrowser affect it?
What if you open 2 Localbrowsers with the Desktop folder selected, then close SmartFTP?
Are the entries written to the registry?
#5 Kravvitz
Kravvitz
  • 15 posts
Posted 23 April 2004 - 03:40 AM
The last local browser that I do something with will be the one opened when I start SmartFTP again.
No change.
Yes.
In the registry, Local Browser 0 is the last local browser that I did something with. It ignores the entries for Local Browser 1 and Local Browser 2.
Thank you for taking the time to look into this. :)
  • 11935 posts
Posted 23 April 2004 - 04:23 AM
I did some minor changes in the latest developer build. But Im pretty sure it doesnt change anything. Im not able to reproduce the problem here. Anyone else with the same problem?
Maybe its related to Windows 98 only.
#7 Kravvitz
Kravvitz
  • 15 posts
Posted 23 April 2004 - 04:33 AM
Yeah, often problems only occur for some of the versions of Windows.
What was changed between Builds 980 and 981?
Is there any chance I could get a copy of Build 980 if you can't find where the problem lies and fix it?
EDIT: Version 1.0.981.45 does not seem to fix it, but I did not reboot after installing it.
#8 bkausbk
bkausbk
  • Translator
  • 241 posts
Posted 23 April 2004 - 01:40 PM
I should also mention that the backup utility doesn't add the extension to the filename.
May be you should enable "Show file name extensions for known files" in explorer settings.
... and saves it to the program directory instead of the %WindowsDir%/Personal/
Are you using Windows 9x?
SmartFTP Backup Tool uses following algorithm to find Data Directory:
1. Get it from "HKCUSoftwareSmartFtpData Path"
if not found it uses default path returned by SHGetSpecialFolderLocation(0, CSIDL_APPDATA, &Pidl)
bkausbk
#9 Kravvitz
Kravvitz
  • 15 posts
Posted 23 April 2004 - 06:23 PM
[quote name='bkausbk][quote=bkausbk]if not found it uses default path returned by SHGetSpecialFolderLocation(0' date=' CSIDL_APPDATA, &Pidl)[/quote']
I guess that is a function in whatever programming language you guys are using?
As I stated before in this thread, I'm using Win98se.
I should explain that the backup tool found both the SmartFTP directory and the SmartFTP Data director, but in the page where you choose the file name and comment, the browse window is set to %WindowsDir%/Personal/, which I didn't bother to change and yet it saved it to the SmartFTP directory without adding the file name extension to the end.
#10 Kravvitz
Kravvitz
  • 15 posts
Posted 26 April 2004 - 03:12 AM
Two other things:
Sometimes when I start SmartFTP it comes up in the same size and position that I had it previously, but it immediately goes back to the default.
When I have View --> Show Panes --> Bottom View enabled, Log doesn't show anything anymore, SmartFTP is set to Log everything, and Session Queue is just a plain grey rectangle, no text or anything.
Thank you for your assistance. :)
