Shows Double Directory
2 replies to this topic
#1 Mr-Fly
Mr-Fly
Posted 08 April 2004 - 04:41 PM
I get the following look in smartftp:
/_borders
_borders
/anholt
anholt
So I get all directories twice. Once with a / in front of it.
The setting "Remove Redundant links" is set.
Version of Smartftp is:
Version : 1.0.981.43
Time Stamp : 2004-03-30 20:44:19
controls.dll : 1.6.981.43
ftpapi.dll : 2.0.981.43
language.dll : 1.0.981.43
reseng.dll : 1.3.981.43
smarthook.dll : 1.0.2.1
shell32.dll : 5.00.3700.6705
shlwapi.dll : 6.00.2800.1400
comctl32.dll : 5.81
riched20.dll : 5.30.23.1215
schannel.dll : 5.00.2195.6705
Version : 6.0.2800.1106
Raw Listing of the directory.
This listing is shortened, I hope we dont need more.
Type=cdir;Modify=20040319220402;Unique=0404001e011ceb00;Perm=cmpdfe; /
Type=cdir;Modify=20040319220402;Unique=0404001e011ceb00;Perm=cmpdfe; .
Type=dir;Modify=19990311035727;Unique=0404001e014836ca;Perm=cmpdfe; /_borders
Type=dir;Modify=19990311035727;Unique=0404001e014836ca;Perm=cmpdfe; _borders
Type=dir;Modify=20031219132335;Unique=0404001e00ff91e0;Perm=cmpdfe; /anholt
Type=dir;Modify=20031219132335;Unique=0404001e00ff91e0;Perm=cmpdfe; anholt
Kind Regards
Thorsten
  • 11972 posts
Posted 08 April 2004 - 08:25 PM
As you can see from the raw directory listing sent back from the server the problem is with the server. You can disable MLST under settings->transfer (global or favorite setting) as a temporary workaround till the developer of the server software fixed the bug.
#3 Mr-Fly
Mr-Fly
Posted 09 April 2004 - 08:53 AM
But how can that be ?
First of all, I remember, that it came with one of the releases.
Its about 6 months ago when it first appeared.
Second, this is the major provider and all other ftp programs get it work.
The provider has about 2.000.000 customers for domains.
If I try leechftp, command line ftp both show only once.
Kind Regards
Thorsten
added:
I tested it with MLSD turned off, you are right, that fixed it for me.
So it must have been the time, where mlsd had be added, when my problems started.
