silent install possible at all?
4 replies to this topic
#1 docjay
docjay
  • 4 posts
Posted 05 April 2004 - 11:56 PM
Is there anyway to do a silent install with SmartFTP ?? I need to include this program with my WinXP CD that is totally automated. I am going to have my regged SmartFTP copy installed along with some others of mine. The installer is a nullsoft installer.. I tried the /S switch which kinda helps out but I am still prompted to hit 'next' to continue the installation.
Are they are other switches I can use with SmartFTP to get the program and the license key installed silently?
Please post a reply SmartFTP moderator!!
Jamie
  • 11954 posts
Posted 06 April 2004 - 08:22 AM
You can use the MSI setup and the cab files for a silent installation. You shouldnt use the NSI (nullsoft) setup for this purpose.
#3 docjay
docjay
  • 4 posts
Posted 06 April 2004 - 01:33 PM
Hey,
you mean the SFTPMSI.exe that you initially download for the installation? That even has an ICON for nullsoft.. please tell me if I should just extract it and what switches to use.
Thanks!
Jamie
  • 11954 posts
Posted 06 April 2004 - 07:35 PM
The SFTPMSI.exe or SFTPFull.exe is a NSI setup which extracts the files from the MSI setup. The MSI installation files are copied to c:Program FilesSmartFTP Setup Files
These are the files necessary for the MSI setup.
#5 docjay
docjay
  • 4 posts
Posted 06 April 2004 - 07:55 PM
kewl, got it.. you the man.. I should have checked there 1st -
Thanks for the tip
Jamie
