Escaped spaces in last component of URL are not unescaped
2 replies to this topic
#1 hanu
hanu
Posted 31 March 2004 - 12:11 AM
When I paste a FTP URL with escaped spaces into the global queue, the escaped
spaces in the last component of the URL path will not be unescaped. In other
words, when SmartFTP sends the file or directory name to the remote FTP server,
it sends '%20' instead of a space as part of the file name. Note, that this only
happens with the last component of the path. Spaces in directory names in front
of that last component are unescaped correctly. Also note that this may happen
for other escaped characters as well and that it may only happen when the last
component contains a dot.
Example (confidential information was Xed out):
When pasting this URL
ftp://user:password@XXX.XXX.XXX.XX/home/u...th%20spaces.txt
into the global queue, the transfer will fail and the following will be logged
(the directory 'dir with spaces' does indeed exist and in that directory there
is file a file called 'file with spaces.txt'):
Resolving host name XXX.XXX.XXX.XX...
Connecting to (XXX.XXX.XXX.XX) -> IP: XXX.XXX.XXX.XX PORT: 21
Connected to (XXX.XXX.XXX.XX) -> Time = 3095ms
220 ProFTPD FTP Server ready.
USER user
331 Password required for user.
PASS (hidden)
230 User user logged in.
SYST
215 UNIX Type: L8
FEAT
500 FEAT not understood.
REST 100
350 Restarting at 100. Send STORE or RETRIEVE to initiate transfer.
REST 0
350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer.
PWD
257 "/home/user" is current directory.
CWD /home/user/mainwebsite_html/dir with spaces
250 CWD command successful.
PWD
257 "/var/www/html/dir with spaces" is current directory.
PWD
SIZE file%20with%20spaces.txt
550 file%20with%20spaces.txt: Forbidden command argument
CWD /home/user/mainwebsite_html/dir with spaces/file%20with%20spaces.txt
550 /home/user/mainwebsite_html/dir with spaces/file%20with%20spaces.txt: Forbidden command argument
This is the [[Please post the system information which can be found in the menu: Help->About "System Information". ][/Please post the system information which can be found in the menu: Help->About "System Information". ]][/[Please post the system information which can be found in the menu: Help->About "System Information". ][/Please post the system information which can be found in the menu: Help->About "System Information". ]]
Service Pack 1 (Build 2600)
CPU Speed : 1598 MHz
Total Memory : 1047792 KB
Free Memory : 382088 KB
Version : 1.0.981.37
Time Stamp : 2004-03-15 11:56:43
controls.dll : 1.6.981.37
ftpapi.dll : 2.0.981.37
language.dll : 1.0.981.37
reseng.dll : 1.3.981.37
smarthook.dll : 1.0.2.1
shell32.dll : 6.00.2800.1233 (xpsp2.030604-1804)
shlwapi.dll : 6.00.2800.1400
riched20.dll : 5.30.23.1211
Version : 6.0.2800.1106
  • 11969 posts
Posted 22 April 2004 - 02:50 PM
Please see latest developer build
the problem has been fixed.
SmartFTP.com
#3 hanu
hanu
Posted 24 April 2004 - 08:36 PM
Fix verified. Works like a charm! Thanks!
