Repeating Global Queue Downloads
2 replies to this topic
#1 John Liebson
John Liebson
  • 3 posts
Posted 12 March 2004 - 02:07 PM
Smart FTP 1.0.980; Windows XP Home, SP1; Intel® Pentium® 4 CPU 2.53GHz; 512 B RAM; "oodles" of free space on hard disk.
Problem: Put file(s) into Global Queue; it/they will download properly.
However, quite often, SmartFTP will then repeat the download of at least one file.
A short time ago, the latest release of Mozilla Thunderbird successfully downloaded, whereupon SmartFTP repeated the operation. There was only one entry in the queue.
I know that the first download has been successful at other times, for I have been sitting at the computer as the SmartFTP first download conlcuded, and have been able to stop the second attempt. At that point, I have run the first download, installing the files from within it for example, with no problem.
I've done a forum search, and have not found any relevant threads, other than the one I posted several days ago in the general public forum, a thread which has received no replies, hence this posting to see if I can get an answer and/or a fix to the problem.
  • 11953 posts
Posted 15 March 2004 - 12:02 AM
My guess is that the control connection got reset during the data transfer and thus no correct reply message from the server is received after the transfer has been completed.
It's a common problem, especially with connections through proxies.
SmartFTP.com
#3 John Liebson
John Liebson
  • 3 posts
Posted 15 March 2004 - 07:05 PM
Thanks for the explanation: Although I don't use a proxy, at least now I understand what causes the problem.
Time to invent an add-on for SmartFTP: A device that mechanically disconnects the phone line from the wall jack upon completion of downloading, waits a few seconds, reconnects the line, all without causing other Internet progams in use to also disconnect....
