Uploading Folders hickup.
5 replies to this topic
#1 thetenguse
thetenguse
  • 5 posts
Posted 13 February 2004 - 03:24 PM
Create a folder, for example TEST001. Open this folder and create a
Subfolder named TEST002.
Now Open SmartFTP and go to where you want to upload TEST001. Right
click the upload folder and select Copy URL.
Open an explorer and drag the TEST001 folder down to the queue source
and drop it. Now Right click on the TEST001 folder in the queue and select
Remote - Enter URL...
Paste the clipboard by hitting CTRL+V and click ok.
Now when you press play in the Global Queue only the Contents of
TEST001 is uploaded, not the actual folder TEST001.
Just thought I should mention it, Love this little program. =)
/Patrik
  • 11975 posts
Posted 13 February 2004 - 05:23 PM
It seems the drag&drop operation to SmartFTP "empties" the clipboard.
We'll take a look at it.
SmartFTP.com
#3 thetenguse
thetenguse
  • 5 posts
Posted 13 February 2004 - 06:49 PM
The clipboard is not the problem here, read the first post again and follow
the instructions.
/Patrik
#4 Caleb
Caleb
  • 73 posts
Posted 14 February 2004 - 12:03 PM
He wants the actual TEST001 folder to be created in the remote destination (copied), and not having its contents copied directly to the remote destination..
what he wants:
/remoteolder/TEST001/files...
what happens:
/remoteolder/files...
#5 mb
  • 11975 posts
Posted 14 February 2004 - 05:01 PM
Before you start getting picky I'd like to point you to the "Bugreport Readme" which can be found as a sticky post in this forum. Your bugreport does not comply with the rules.
Nevertheless we'll fix the bug/problem in a future build.
Thanks for reporting.
SmartFTP.com
  • 11975 posts
Posted 17 February 2004 - 02:32 AM
The bug has been fixed in the latest build 1.0.981.10.
SmartFTP.com
