Problems with SmartFTP Secure FTP (TLS-C) through proxy
5 replies to this topic
#1 jrdepriest
jrdepriest
  • 8 posts
Posted 03 February 2004 - 08:55 PM
Service Pack 4 (Build 2195)
CPU Speed         : 996 MHz
Total Memory      : 392688 KB
Free Memory       :  73732 KB
Version           : 1.0.980.1
Time Stamp        : 2003-12-13 01:25:08
controls.dll      : 1.6.980.1
ftpapi.dll        : 2.0.980.1
language.dll      : 1.0.980.1
reseng.dll        : 1.3.980.1
smarthook.dll     : 1.0.2.1
shell32.dll       : 5.00.3700.6705
shlwapi.dll       : 6.00.2800.1276
comctl32.dll      : 5.81
riched20.dll      : 5.30.23.1215
schannel.dll      : 5.00.2195.6705
Version           : 6.0.2800.1106
Winsock           : 2.2
I am trying to connect to an AIX system running Connect:Enterprise with the Secure FTP option enabled.
My Internet connectivity is through a proxy server and firewall.
The proxy server support SOCKS5 (which is what I am using) and the firewall requires using PASV for FTP traffic.
I am able to connect to the remote system, but something strange happens with the key exchange and then I get disconnected before I can perform any file transfer actions.
Here is a (sanitized) log:
*          SESSION STARTED AT 03.Feb.2004 14:40:50
    Resolving host name proxy.domain.com...
    Resolving host name 111.222.333.444...
    Connecting to Proxy (proxy.domain.com) ->  IP: AAA.BBB.CCC.DDD PORT: 1080
    Connected to Proxy (proxy.domain.com) -> Time = 0ms
220 <<<Connect:Enterprise UNIX 2.1.00 Secure FTP>>> at ftbce02 FTP server ready. Time = 14:43:47
    AUTH TLS-C
234 AUTH TLS-C/TLS OK.
    PBSZ 0
200 PBSZ 0 OK.
    USER test
331 Password required for test.
    PASS (hidden)
230 Connect:Enterprise UNIX login ok, access restrictions apply.
    SYST
215 UNKNOWN Type: L8
    REST 100
550 Operation is not supported under Connect:Enterprise FTP server.
    TYPE I
200 Type set to I.
    REST 100
    PWD
257 "/test" is current directory.
    TYPE A
200 Type set to A.
    PROT P
200 PROT P OK, data channel will be secured.
    PASV
227 Entering Passive Mode (192,168,248,27,33,103)
    LIST -aL
    Opening data connection IP: 192,168,248,27,33,103 PORT: 8551.
    SSL Error
    The operation completed successfully.
    Connection closed. Server timeout.
    NOOP
    Command aborted by user.
*          SESSION  CLOSED AT 03.Feb.2004 14:42:40
It doesn't appear to show up in the log, but the remote port I am connecting to is 20021 instead of 21.
  • 11953 posts
Posted 04 February 2004 - 01:12 AM
It seems to be an incompatibility between SmartFTP and the AIX FTP server.
Have you created and selected a self signed cert under Menu: Tools->Settings->SSL?
We can debug the problem if we have FTP access (read only would be sufficient) to the server. Otherwise we cannot do much to solve the problem.
Please post your license key (without sig) in the future.
SmartFTP.com
#3 jrdepriest
jrdepriest
  • 8 posts
Posted 04 February 2004 - 06:11 PM
I have created the self-signed key and tried the connection both with and without it and it fails both times.
I do not have ownership of the system I am connecting to. I will inquire about read access to troubleshoot this problem.
  • 11953 posts
Posted 23 February 2004 - 05:06 PM
Try latest developer build.
SmartFTP.com
#5 jrdepriest
jrdepriest
  • 8 posts
Posted 23 February 2004 - 05:23 PM
That might have worked.
I was able to connect without an error.
I uploaded a file, but was not able to see it after uploading it.
I am trying to verify the level of permissions the ID I have has on the 'test' directory I am connecting to.
This may be normal behaviour.
Thank you, regardless.
I'll post an update when I have any answers.
#6 jrdepriest
jrdepriest
  • 8 posts
Posted 23 February 2004 - 05:51 PM
Success!
Sent: Monday, February 23, 2004 11:47 AM
To: DePriest, Jason R.; McKnatt, Chris C.
Subject: RE: SmartFTP transfer completes successfully... I think
This is what I found;
Mbx ID          Batch #          Batch ID                  Bytes             Date-Time              Status           Org ID
test            141            DBVersionChange.sql         97              04/02/23-11:23             CFGY            test
Looks good to me.
Malcolm
-----Original Message-----
Sent: Monday, February 23, 2004 11:40 AM
To: McKnatt, Chris C.; Holland, Malcolm
<<DBVersionChange.sql>>
This is the file I uploaded.
You guys are the best!
Keep up the great work.
-Jason
