Broken ftp transfer
#1 mark_p_baldwin
mark_p_baldwin
Posted 20 January 2004 - 05:27 PM
I am trying to transfer multiple files from several directories on a remote machine. The structure is
/am/yyyy/mm/file1, file2, etc. mm ranges from 01 to 12. In the example below yyyy is 1969.
The log shows (after transferrinh hundreds of files):
226 Transfer complete.
PASV
227 Entering Passive Mode (130,246,191,168,138,95).
Opening data connection IP: 130,246,191,168,138,95 PORT: 35423.
RETR lfam19690419.nc
150 Opening BINARY mode data connection for lfam19690419.nc (9483764 bytes).
9482240 bytes received successfully. (112.93 KB/s) (00:01:22).
CWD /badc/.e40_daily_avs/am/1969
250 CWD command successful.
PWD
TYPE A
257 "/badc/.e40_daily_avs/am/1969" is current directory.
PASV
200 Type set to A.
227 Entering Passive Mode (130,246,191,168,138,96).
PWD
Cached directory reloaded.
257 "/badc/.e40_daily_avs/am" is current directory.
PWD
PASV
227 Entering Passive Mode (130,246,191,168,138,97).
NOOP
200 NOOP command successful.
NOOP
NOOP
NOOP
NOOP
421 No Transfer Timeout (300 seconds): closing control connection.
Connection closed.
SmartFTP is not resuming the transfer, but I do not understand why. How can I make sure that smartFTP resumes transfers?
Mark P. Baldwin
mark@nwra.com
  • 11971 posts
Posted 20 January 2004 - 06:22 PM
Use the global queue.
http://www.smartftp.com/support/howto
Please post your license key (without signature) for further inquiries.
SmartFTP.com
