smartFTP (UPnP) and SpeedTouch 510v4 ?
3 replies to this topic
#1 Etienne
Etienne
    France
Posted 27 November 2003 - 08:53 PM
I've a problem. I'be a UPnP compatible compatible modem (the SpeedTouch 510v4) but smartFTP seems not to interact with him !
Here is a log (it's in french) of an attempt to connect to ftp.ens-cachan.fr/mirror/Mandrake/9.2/i586
Everything is set to default
[quote]
   R
#2 Louie
Louie
  • 337 posts
    New York City
Posted 29 November 2003 - 07:53 AM
Make sure you have UPnP enabled in the router settings.
Routers such as Linksys do not enable UPnP by default.
You will also want to install the latest SmartFTP build.
If still no luck. Please connect to the SmartFTP public FTP,
and paste the log. Make sure to login in "Active Mode".
#3 Etienne
Etienne
    France
Posted 29 November 2003 - 10:00 AM
I installed the build 980, but it still doesn't work.
I connected to the SmartFTP public ftp, but it doesn't work either. I am in Active Mode.
Here is the log :
   Resolving host name ftp.smartftp.com...
   Connecting to (ftp.smartftp.com) ->  IP: 213.144.155.6 PORT: 21
   Connected to (ftp.smartftp.com) -> Time = 220ms
220-SmartFTP Server
220 service ready
   USER anonymous
331 User name okay, need password.
   PASS (hidden)
230 User logged in, proceed.
   SYST
215 UNIX Type: L8
   FEAT
211-Extensions supported:
SIZE
REST
MDTM
AUTH TLS
AUTH SSL
PBSZ
PROT
CLNT
SSCN
XCRC
EPRT
EPSV
MLST type*;size*;modify*;create*;perm*;unix.owner;unix.group;windows.lastaccesstime;
211 END
   Detected Server Software: BlackMoon
   CLNT SmartFTP 1.0.980
200 Noted.
   PWD
257 "/" is the current directory
   TYPE A
200 Command okay.
   PORT 10,0,0,2,13,78
200-Private IP address range "10.0.0.2" detected in data port command.
200-Using control connection ip "81.56.232.6" for your data connection instead
200 Command okay.
   Opening data connection IP: 10.0.0.2 PORT: 3406.
   MLSD
150 File status okay; about to open data connection.
   Connection closed. Server timeout.
425 Timeout occurred while attempting to connect to 81.56.232.6 [REF: 36F44DDFAB3F]
The UPnP on my modem is enabled, and works, since MSN Messenger is able to create rules.
Do you need technical informations about this modem ?
Etienne
#4 noel05
noel05
Posted 12 February 2004 - 07:40 AM
I'm using a ADSL NAT router (no support UPnP). I connected to ftp.smartftp.com with both active mode and passive mode. And I don't understand how the server ftp.smartftp.com work. With another FTP server, It cannot connect with active mode.
With passive mode:
[quote]
Connected to (ftp.smartftp.com) -> Time = 1011ms
220-SmartFTP Server
220 service ready
USER anonymous
PASS (hidden)
SYST
215 UNIX Type: L8
FEAT
SIZE
REST
MDTM
AUTH TLS
AUTH SSL
PBSZ
PROT
CLNT
SSCN
XCRC
EPRT
EPSV
211 END
200 Noted.
PWD
TYPE A
200 Command okay.
PASV
227 Entering Passive Mode (213,144,155,6,62,156)
Opening data connection IP: 213,144,155,6,62,156 PORT: 16028.
MLSD
142 bytes received successfully. (142 B/s) (00:00:01).
226 Closing data connection. Transfer Complete (142 bytes)
CWD /SmartFTP
250 Requested file action okay, completed.
PWD
257 "/SmartFTP" is the current directory
PASV
227 Entering Passive Mode (213,144,155,6,62,186)
Opening data connection IP: 213,144,155,6,62,186 PORT: 16058.
MLSD
2457 bytes received successfully. (0.60 KB/s) (00:00:04).
226 Closing data connection. Transfer Complete (2457 bytes)
[/quote]
with active mode
[quote]
Connected to (ftp.smartftp.com) -> Time = 822ms
220-SmartFTP Server
220 service ready
USER anonymous
PASS (hidden)
SYST
215 UNIX Type: L8
FEAT
SIZE
REST
MDTM
AUTH TLS
AUTH SSL
PBSZ
PROT
CLNT
SSCN
XCRC
EPRT
EPSV
211 END
200 Noted.
PWD
CWD /SmartFTP/Special
PWD
257 "/SmartFTP/Special" is the current directory
TYPE A
200 Command okay.
PORT 172,16,0,81,6,236
200 Command okay.
Opening data connection IP: 172.16.0.81 PORT: 1772.
MLSD
72 bytes received successfully. (72 B/s) (00:00:01).
226 Closing data connection. Transfer Complete (72 bytes)
[/quote]
what does UPnP support mean ?[/quote]
