Secure connection
6 replies to this topic
#1 wecksell
wecksell
Posted 13 November 2003 - 11:07 AM
Symptom:
systems laggs and smartftp uses 100% CPU
Happens when:
I connect to a host with FTP over SSL Explicit and the connection i shutdown by the server because of idleness. When I just press Refresh on the file view, nothing happens, normaly it reconnects but i can understand that it may be difficult using a secure connection. But the symptom shows when i close that fileview(connection) and press enter in the quickconnect again (the history saves the connection and i press enter to reconnect in the url-bar).
The server is ProFTPd using the TLS module. I can give you more information on the server if you like.
Hope this is of value. Just let me know and I'll help you in anyway.
Service Pack 1 (Build 2600)
CPU Speed : 2403 MHz
Total Memory : 523760 KB
Free Memory : 166000 KB
Version : 1.0.979.7
Time Stamp : 2003-11-06 18:26:29
controls.dll : 1.6.979.7
ftpapi.dll : 2.0.979.7
language.dll : 1.0.979.7
reseng.dll : 1.3.979.7
smarthook.dll : 1.0.2.1
shell32.dll : 6.00.2800.1233 (xpsp2.030604-1804)
shlwapi.dll : 6.00.2800.1226
riched20.dll : 5.30.23.1211
Version : 6.0.2800.1106
#2 Louie
Louie
  • 337 posts
Posted 29 November 2003 - 09:56 AM
I can't produce this, is this still occuring for you?
And if anyone else can try producing it, please give it a shot!
#3 wecksell
wecksell
Posted 29 November 2003 - 10:19 PM
After a reinstall of XP it still occurs. Shouldn't have to do with what kind of server I'm connecting to right? I'ts ProFTPd if matters. I didn't check if it occurs directly after reinstalling my OS, that is, all my applications and utilities was installed when i remembered to check if the bug was still there, and it is.
CPU Speed : 2402 MHz
Free Memory : 298712 KB
Version : 1.0.979.7
shlwapi.dll : 6.00.2800.1276
  • 11969 posts
Posted 18 December 2003 - 05:03 PM
Hi.
Install latest SmartFTP build then try again.
SmartFTP.com
#5 PeterK
PeterK
Posted 22 December 2003 - 10:29 AM
I have the same problem.
Shortly after I loose the connection to the server cause of idleing, the cpu usage goes to 100%. Even if I close the remote window, the cpu usage stays at 100%. I have to restart SmartFTP completely to get the problem solved.
I'm using FTP over SSL explicit.
Auth mode is TLS
Data connection mode is Private Data Connection
Here are my details:
Registration Data:
CPU Speed         : 1295 MHz
Total Memory      : 1047792 KB
Free Memory       :  626008 KB
Version           : 1.0.980.1
Time Stamp        : 2003-12-13 01:25:08
controls.dll      : 1.6.980.1
ftpapi.dll        : 2.0.980.1
language.dll      : 1.0.980.1
reseng.dll        : 1.3.980.1
smarthook.dll     :
Winsock           : 2.2
  • 11969 posts
Posted 22 December 2003 - 05:11 PM
Please install the latest developer build:
SmartFTP.com
#7 PeterK
PeterK
Posted 22 December 2003 - 07:57 PM
Looks much better now, thx ;)
