Closing IE Triggers Clipboard Monitor
#1 neocryptek
  • 7 posts
Posted 11 October 2003 - 10:23 PM
Hey, i just wanna say thanks for this BRILLIANT! piece of code you have here, awesome job!
I have this really annoying problem, when i have clipboard monitoring on, everything works fine. Untill i close an IE window, then SmartFTP triggers on the clipboard and tries to open 1-3 connections to the address in the clipboard, this seems to only work for the IE that you copied the address from (I right click->copy shortcut)
My stats:
Windows XP SP1
SmartFTP 1.0.979.1
IE 6.0.2800.1106
#2 Louie
  • 337 posts
Posted 11 October 2003 - 10:43 PM
You should of performed a Search on the forum(s) first.
This has already been stated in the Known Issues thread.
