Address editor
3 replies to this topic
#1 toralux
  • 3 posts
Posted 31 March 2003 - 09:51 AM
I'm missing a Address editor (both local and remote) where you can edit the current active directory without browsing a treeview (often entering a path is faster than browsing for it).
#2 darix
  • 181 posts
Posted 31 March 2003 - 12:45 PM
enable the command line ( view show panes -> command line or press shift+f5 )
this works at least for remote view
you can navigate there via simple
CWD <path>
hope this helps
#3 toralux
  • 3 posts
Posted 07 May 2003 - 03:03 PM
I need the address-bar especially for the local browser. I use Windows Explorer and there should be an easy way to copy / paste a path from Windows Explorer (or manually edit it for faster navigation).
#4 Mike
  • Root Admin
  • 194 posts
Posted 07 May 2003 - 10:17 PM
You can use the URL combobox for this if you enter a local path here
a local browser gets open or if a local browser is active its current path
is changed.
Hope this help
