serv-u virtual dir mappings
7 replies to this topic
#1 Gazz
Gazz
  • 5 posts
Posted 03 March 2003 - 11:22 AM
Hi all,
I have spent sometime trying to fix this problem but to no avail, but I'll try to describe it as best I can.
I'm using 4.0.0.4 of serv-u and SmartFTP 1.0.973
In serv-u I have two virtual dir mappings....
1...
physical = d:blah
mapped to = c:test
virtual name = blah
2...
physical = 10.0.5.2blah2
mapped to = c:test
virtual name = blah2
The virtual mapping using the UNC path name (2) doesn't show in the dir listing, but the local mapping using drive letters does (1)
I have used many other clients and they all show the dir blah2 (2). Using the other clients I can enter the dir, download, etc, etc all as you'd expect. I have also tested this with the latest version of serv-u but the same problem appears as above.
So I think their could be a bug showing this UNC virtual path.
Ah - also forgot to mention that I can use the "change folder" command to enter the dir that doesn't appear in the list.
Great application, keep up the good work!
Garry.
Service Pack 1 (Build 2600)
CPU Speed : 1817 MHz
Total Memory : 523760 KB
Free Memory : 206912 KB
Version : 1.0.973.1
Controls.dll : 1.6.973.1
FTPAPI.dll : 2.0.973.1
Language.dll : 1.0.973.1
ResEng.dll : 1.3.973.1
shell32.dll : 6.00.2800.1145 (xpsp2.021108-1929)
shlwapi.dll : 6.00.2800.1106 (xpsp1.020828-1920)
riched20.dll : 5.30.23.1211
Version : 6.0.2800.1106
#2 darix
darix
  • 181 posts
Posted 03 March 2003 - 11:45 AM
try to disable "remove redundant links" (tools -> settings -> transfer -> dirlisting options)
maybe this helps
darix
#3 Gazz
Gazz
  • 5 posts
Posted 03 March 2003 - 11:52 AM
Thanks....
Nope that still doesn't show the dir.
Garry.
  • 11972 posts
Posted 04 March 2003 - 03:28 AM
Post the raw directory listing:
right mouse click on folder -> show raw listing
and include the the important part from the log.
#5 Gazz
Gazz
  • 5 posts
Posted 04 March 2003 - 10:47 AM
Ok...
Here is the raw dir listing, before chnging folder to blah2....
drw-rw-rw- 1 user group 0 Mar 4 10:34 .
drw-rw-rw- 1 user group 0 Mar 4 10:34 ..
dr--r--r-- 1 user group 0 Feb 28 16:11 Blah
-rw-rw-rw- 1 user group 0 Mar 4 10:26 New Text Document.txt
drw-rw-rw- 1 user group 0 Mar 4 10:31 Normal
I can "change folder" to blah2, it'll allow me and display it in the folder window, but when I do a raw listing and it doesn't show. Once I change folder I can do everything as normal.
"Blah" is also a virtual mapping, but to the local machine.
Here is the log of the change to blah2.....
200 Command okay.
CWD Blah2
250 Directory changed to /Blah2
PWD
257 "/Blah2" is current directory.
PASV
227 Entering Passive Mode (x,x,201,19,31,76)
Opening data connection IP: x.x.201.19 PORT: 8012.
LIST -aL
150 Opening ASCII mode data connection for /bin/ls.
59 bytes received successfully. (59 B/s) (00:00:01).
226 Transfer complete.
And changing to blah....
CWD /Blah
PWD
257 "/Blah" is current directory.
PASV
227 Entering Passive Mode (x,x,201,19,31,73)
Opening data connection IP: x.x.201.19 PORT: 8009.
LIST -aL
6133 bytes received successfully. (5.99 KB/s) (00:00:01).
If you need anymore let me know.
Garry.
  • 11972 posts
Posted 05 March 2003 - 01:46 AM
We cannot do anything about it, if the directory doesn't show up in the raw directory listing.
Sorry.
#7 Gazz
Gazz
  • 5 posts
Posted 05 March 2003 - 07:30 AM
Ah that's a shame.
So you use a 3rd party FTP engine? If so which one?
If I can "change folder" to a directory that is not showing, then their is a problem with the directory listing, whether its raw or not?
#8 Gazz
Gazz
  • 5 posts
Posted 06 March 2003 - 10:26 AM
Hey guys,
Moving this post to "Users Helping Users" rather than a bug it not going to help it go away.
Hey, throw me a life line here. Just a tiny bit of help? Every other FTP client under the sun from Unix to Windows lists this directory. Would you fex it if I bought the software?
SmartFTP is great and I want to use it, make it better and fix this bug.
Any help appreciated, Thanks.
